95 - 91 240sx engine swap question
AJtheMishima
09-21-2003, 10:43 PM
Im about to get my hands on a KA24DE+ tranny from a 95 sx and im gonna install it into a 91sx. What things will i need to watch out for and get for this swap? Thnx
AJtheMishima
09-22-2003, 01:26 AM
Just for more insight on exactly what im getting heres what the guy im buyin the motor from originally wrote...
"Selling a KA24DE+ tranny from a 1995 240sx with ~120k miles. Engine still runs excellent, and I still have all the service records for it. It is currently still in the car, so potential buyers can drive it before it comes out. I am selling the engine and tranny combo, including all the accessories (ac/alt/ etc. etc) . What will not come with the engine is the main harness, the speed sensor, and temp. sensor. (those items can be easily picked up at any junk yard). I need these pieces for my SR swap."
Just another thing, your probably thinkin to urselves, why a ka24de swap instead of a sr20, cause i cant afford it right now plus the motor in the 91 isnt workin. And this is a pretty cheap alternative. So any help on this swap will be greatly appreciated. Thnx
stealthj
09-22-2003, 02:10 AM
hmm, it shouldent be hard, same exact engine, the sensor and wire stuff is off your old engine, so not hard at all
AJtheMishima
09-25-2003, 11:05 PM
So i wont need anything else for this swap????
SR20DETpower
09-26-2003, 09:08 AM
I MIGHT be wrong..... but I think the newer engines have something diffreent about them? maybe Jspec or Dorikin might know this, I could be totally wrong though. It should work in any case, just might need a little extra work then a KA from the same year. Atleast you got a newer engine that hadn't been been abused for 10 years =)
Suislide
09-26-2003, 03:58 PM
i'm pretty sure the engines are the same. should be a direct, easy swap over. good luck!
AJtheMishima
09-27-2003, 12:31 PM
Lots of peeps tell me it should be an easy swap, but i may need a new harness, here what someone from my local forums wrote.
"If your 92 engine still runs good I wouldn't bother with the swap. There is no power difference as you know and the 95 will have slightly different wiring because it is an OBDII engine, which requires a secondary down stream O2 sensor to be installed as well.
Wiring in the accessories may also be different.
W/o the S14 main harness you will run into some issues due to differences between OBDI and OBDII."
What do you'll think, I know bout ka engines but nothin on obdi and shit. Thnx
Suislide
09-27-2003, 12:45 PM
well, is your '92 engine running fine? if so, i'd say don't bother with the swap for now and focus on getting a turbo kit for it or a different engine swap, say CA or SR or RB of some sort...?
AJtheMishima
09-28-2003, 02:42 AM
Nah, the engine in the 92 is blown the fuck out, thats why i wanna do this cheap little swap till i get my real engine. Ill probably go in the rb path.
