SRS Light Reset please helplightnoch 09-21-2003, 06:12 PM any one here know how to reset the SRS so the light will go out i know its simple and fast my friend knows how to do it but wont tell me he did it on my car(when i wasnt there) i even saw him do it on his car ones at the end i came up and he unpluged something under the stearing wheel and placet a wire in side the plug while the car was on and the light whent away you start the car the light goes on and then goes away just like it should be so much for a rest any one knows the details to this, said will work on any honda or acura model year lorunner 09-25-2003, 10:29 PM nice friends! its easier with a scan tool lightnoch 09-25-2003, 10:59 PM whats a scane tool and where do i get it?, if its like $5 bucks i wouldnt mind cause this reset is soooooo simple just place a wire is some plug and yor done Tiger_maverick 11-13-2003, 10:40 AM there is a yellow plug under the dash that has two wires going into it. the plug is plugged into an empty socket by the fuse pannel. take that plug out, place a jumper wire into the two holes connecting the two. turn the ignition key on.(lights on do not start) the srs light will go off, within 4 seconds, unplug one side of the jumper wire, when the srs light comes back on plug the jumper back in,(within 4 seconds) the light will blink twice and go out. unplug the jumper and turn the ignition key off. wait 15 secongs, then start your car. the memory will be reset. replace the plug and you're set. i am an ase certified mechanic and can't believe that we have a forum that noone will share this information on. what is this place for anyway?. sorry you had to go through this. but i feel that " Buy a scan tool " is the most stupidest responce. if i wanted to spend $900.00 on a tool, i'd pay the $200.00 to have the dealer do it. my goodness. manjitr 02-26-2004, 11:51 PM has anyone tried this on a 2002 accord lx v6 sedan ? iam having trouble finding the yellow plug. thank you albertopirela 03-06-2004, 01:39 PM They could help me I have a Civic LX 94 and I want reset my light of SRS, please if they can be specific as making it, I don't speak English very well thank you lorunner 03-21-2004, 03:24 PM there is a yellow plug under the dash that has two wires going into it. the plug is plugged into an empty socket by the fuse pannel. take that plug out, place a jumper wire into the two holes connecting the two. turn the ignition key on.(lights on do not start) the srs light will go off, within 4 seconds, unplug one side of the jumper wire, when the srs light comes back on plug the jumper back in,(within 4 seconds) the light will blink twice and go out. unplug the jumper and turn the ignition key off. wait 15 secongs, then start your car. the memory will be reset. replace the plug and you're set. i am an ase certified mechanic and can't believe that we have a forum that noone will share this information on. what is this place for anyway?. sorry you had to go through this. but i feel that " Buy a scan tool " is the most stupidest responce. if i wanted to spend $900.00 on a tool, i'd pay the $200.00 to have the dealer do it. my goodness. I hope you aren't talking to me like that. because I never said to buy a scan tool. :nono: trod01 03-28-2004, 11:49 AM I tried the yellow plug trick but I still have my srs light on ...? As the procedure say, I plug a wire, light goes off, unplug one side but the light blink only one time ...? Any idea ? Dan fakename 02-15-2005, 01:47 PM I tried the yellow plug trick but I still have my srs light on ...? As the procedure say, I plug a wire, light goes off, unplug one side but the light blink only one time ...? Any idea ? Dan I also tried the yellow plug trick and got the same problem. We must be missing a step? Anybody? thequietkid 02-26-2005, 10:34 PM If all else fails, you could probably try to simply disconnect the battery for about a minute (approximately 13 seconds at least) and the car's computer will usually reset, on a Honda. It works on resetting the check engine light (if the problem has been taken care of). However, If you have a stock radio make sure it does not have an anti theft code. This will trip it. It's really simple, guess it's worth a shot. lightnoch 02-26-2005, 11:11 PM I tried the yellow plug trick but I still have my srs light on ...? As the procedure say, I plug a wire, light goes off, unplug one side but the light blink only one time ...? Any idea ? Dan 1. How did the light come on in the 1st place ?, airbags deployed then youll need to replace the srs unit, it cannot be reset reset only works if you unpluged the airbag or something gone wrong out of the sky light blue lightnoch 02-26-2005, 11:20 PM If all else fails, you could probably try to simply disconnect the battery for about a minute (approximately 13 seconds at least) and the car's computer will usually reset, on a Honda. It works on resetting the check engine light (if the problem has been taken care of). However, If you have a stock radio make sure it does not have an anti theft code. This will trip it. It's really simple, guess it's worth a shot. 1. disconnecting the battery wont do a dam thing and also it wont reset the check engine light on "hondas" this works on all cars, but it doesnt reset it. , when you disconnect the battery it looses all power computer resets it self and there is NO DATA in the computer it self and it cannot read any problems your car has, but after you drive for a wile around 100 miles, your check engine light will come back, you need to replace the sensors on the exhaust or main fold, Auto zone does a FREE check on cars 96 and up 2. take the radio out, get the serial off it, call your car make dealer and ask for a code, will take 3 sec fakename 02-27-2005, 11:55 AM 1. disconnecting the battery wont do a dam thing and also it wont reset the check engine light on "hondas" this works on all cars, but it doesnt reset it. , when you disconnect the battery it looses all power computer resets it self and there is NO DATA in the computer it self and it cannot read any problems your car has, but after you drive for a wile around 100 miles, your check engine light will come back, you need to replace the sensors on the exhaust or main fold, Auto zone does a FREE check on cars 96 and up 2. take the radio out, get the serial off it, call your car make dealer and ask for a code, will take 3 sec what happened to the original question? it appears that the only way to clear an errant SRS light is to take in to the dealer and take it hard right in the wallet! one last thought, anybody? Tiger_maverick? lightnoch 02-27-2005, 12:11 PM what happened to the original question? it appears that the only way to clear an errant SRS light is to take in to the dealer and take it hard right in the wallet! one last thought, anybody? Tiger_maverick? I told you it all depends on HOW your light came on. you can try the reset again see if it will work (play with it a little maybe your doing it wrong) Also this reset only works on FEW makes, Honda, Acura, Maybe Nissan ? defently doesn not work on any of the american cars but if the Module is bad youll need to replace it and it cost around 300+ bucks depending on your car I can also Reset the SRS Module it self if your intrested for $120 + you ship the srs unit to me, i can only do this for any Imports from 95-05, no american cars so dont ask what car you got ? thequietkid 02-27-2005, 06:20 PM The key words are "IF THE PROBLEM HAS BEEN TAKEN CARE OF". I've done it before. It worked just fine. Also, if the problem has not been taken care of, the computer will usually sense it before 100 miles most instances. Check engine basically deals with emissions and that does not instantly mean sensors in the exhaust. If there is no data in the computer then it would have to default to the original settings. If it doesn't find anything wrong after that, why would the light come back on? It takes less than a minute to try, so what's the harm? 1. disconnecting the battery wont do a dam thing and also it wont reset the check engine light on "hondas" this works on all cars, but it doesnt reset it. , when you disconnect the battery it looses all power computer resets it self and there is NO DATA in the computer it self and it cannot read any problems your car has, but after you drive for a wile around 100 miles, your check engine light will come back, you need to replace the sensors on the exhaust or main fold, Auto zone does a FREE check on cars 96 and up 2. take the radio out, get the serial off it, call your car make dealer and ask for a code, will take 3 sec fakename 02-27-2005, 07:09 PM I told you it all depends on HOW your light came on. you can try the reset again see if it will work (play with it a little maybe your doing it wrong) Also this reset only works on FEW makes, Honda, Acura, Maybe Nissan ? defently doesn not work on any of the american cars but if the Module is bad youll need to replace it and it cost around 300+ bucks depending on your car I can also Reset the SRS Module it self if your intrested for $120 + you ship the srs unit to me, i can only do this for any Imports from 95-05, no american cars so dont ask what car you got ? I have a 02 CR-V. It started when i added a bass unit under the seat and had to disconnect the wiring which i now believe was in the SRS loop. i did not disconnect the battery first. at least thats what the honda shop is telling me and its $80 for them to clear it. he did tell me that the srs system would still work so i may just live with it. lightnoch 02-27-2005, 09:04 PM then you are fine, just do the Reset again , read thru it properly, and try say 10 more times before you get it right, the wire reset will work fine you just have to do it right Just get a peace of wire sharpen both ends and fallow thouse instractions, hopeing that everything was pluged in properly danielcadima 04-15-2006, 12:00 PM hi i'll give you a web where is eaxactly how it is but after that please help out to try to find out where the hell is the SRS MODULE IN A 95 HONDA CIVIC EX OK THANKS http://www.geocities.com/myintegra96/srs.html Automotive Network, Inc., Copyright ©2012
