95 accord braking noise
emtbasic83
09-21-2003, 03:11 PM
about a week ago my brakes staring making the worst noise whenever i drove. i can tell it is coming out of the front passanger wheel, but dont have a clue what it could be. the noise is a scraping metal noise that is constant whenever i drive, and worse when i back up, but goes away when i brake. i dont think it could be a cv joint because it gets a little better when i turn. im thinking it probably it is the pad letting me know my pads are almost done. any thoughts?
BullShifter
09-21-2003, 03:49 PM
most likely your brake pads are worn either to the wear indicator, or completely(broke off wear indicator) either way you need a brake job NOW! Wait too long & you may need new rotors instead of a resurface on your current rotors. If you rotors have been cut too many times you will need rotors anyways.
Your brake fluid should be slightly low if pads worn & the fluid was never topped off.
I suggest Honda brake pads, not some midas "lifetime" pads - which are JUNK! The only time I suggest something other than Honda pads is for performance - EBC makes some nice pads.
