Shaky Braky accord
AccordSleeper504
09-20-2003, 11:59 PM
Sup yall,
My aftermarket rims recently broke on the interstate (long story) and I have some temporary 14 inch factory rims. They are not my factory rims though. I have an EX which i believe are suppose to be 15 inch. Recently I have also tried to swap out my rotors to drilled and slotted but was unable to so put factory rotor back on. My problem is that when i brake, the whole car shakes bad and I am thinking that maybe it is the 1 inch smaller rims i am using. The rotors mayb hitting the rim. Could this really be the problem or is it from my rotors i tried to replace but was unable to? Does anyone else have a such problem? I checked my rims and do not see any impact from the brake calipers or rotors to the rims. Help me out guyz!!!!
badassaccordriver
09-22-2003, 12:49 AM
i had the same problem on my 95 accord, and i checked the rotors to find that both of them were badly warped. after i replaced them, the shaking at high speeds stopped.
epic69
09-24-2003, 09:59 AM
I wonder if i have warped rotors, I seem to get the shakes if i press the brakes hard at highway speeds. how would i know for sure by looking at the rotors if they are warped or not? What would need to be done? Replace? or get them turned?
dutchaccord
09-24-2003, 11:55 AM
get them turned
u can't see it
epic69
09-24-2003, 12:42 PM
So you are saying dutch that I should just get them turned and that should fix it? Shouldnt be too expensive to do that correct? Would you get both front and rear pairs turned all 4 at same time?
92lx
09-24-2003, 03:12 PM
very cheap to get them turned, and that'll likely solve the problem
- Nathan
epic69
09-24-2003, 04:45 PM
Thanks for the advice.
dutchaccord
09-24-2003, 05:02 PM
- Nathan
get the front disks turned...... 90% problem solved
