cheap mods!!!!!!!!
crabby760
09-18-2003, 11:22 PM
i have a 93 dx coupe with a jdm b16a swap i only added so far a injen cold air intake, ngk plugs and 8.5 mm magnecor wires im curios can anyone tell me any little tweaks or tunes i can do to get some more kick out of my motor anything will help me out things i can do my self cause right now i dont have cash for header or exhaust... thanks
90CRXZCSi
09-18-2003, 11:36 PM
well what do you plan on doing? If you dont have any money, how are you going to mod it? Are you on a budget of $100,200??? Let us know and we can help you out more.
crabby760
09-18-2003, 11:43 PM
as of right now i dont got cash to buy anything really.... i just wanted to know some minor tweaks or tunes i can do myself to get some more KICK out of my b16a
dirty91crx
09-18-2003, 11:47 PM
advance ig timing for better low end pull. lighten the car...ie pull seats...carpet etc...gut out ur cat....
crabby760
09-18-2003, 11:51 PM
dont want to strip any interior isnt there any tweaks i can do to the motor to get more bottom or top end? there gotta be something....
crabby760
09-19-2003, 01:09 AM
ok i guess there isnt anything i can tweak out or tune my self?
BullShifter
09-19-2003, 02:20 AM
Speed cost money, how fast do you want to go?
Advancing the timing is about the only free "mod"
There are many things you could do yourself if you have the skill. Like porting/polishing intake manifold, throttle body, & head. Dont try it for the 1st time on your own daily driver, chances are you'll be buying a new head.
Aftermarket exhaust & header wont really do much for performance on a stock engine, 5-7HP.
crabby760
09-19-2003, 02:22 AM
how do i advance or retard my timing?
BullShifter
09-19-2003, 02:36 AM
with a timing light
this for a 91 but all honda 4 bangers are pretty much the same for adjusting - different specs
http://www.binghamtonlife.com/manual/2gsm/images/91-23-58.jpg
BullShifter
09-19-2003, 02:47 AM
before you adjust your timing I suggest marking your distributor before just in case you goof some how. Your next question . . . How do I mark the dizzy? Easy way - use a scratch awl & scribe a line from dizzy to cylinder head(top adjusting bolt) or clean area then use a black permanent marker & do the same thing, except sniff the marker a few times :eek7:
Also marking is a good idea before removing the dizzy so you dont have time after intalling. Just match up the lines.
90CRXZCSi
09-19-2003, 08:36 AM
the dist. is about the only "free" mod there is. Everything else costs money... :redface:
Milliardo
09-19-2003, 03:05 PM
Another free mod I can think of is adjusting the throttle cable, so that you have a higher idle rev. Won't add any hp gains, but at least you'll jump quicker off the line.
BullShifter
09-19-2003, 10:01 PM
Why not just rev the engine more before taking off?
:screwy: normally the throttle isn't 100% tight, there is some free play. You can tighten the cable for better throttle control. If your gonna adjust the idle, the throttle cable is the wrong way. Besides a goofed, idle your engine will rev higher @ idle while in motion - then after you stop it will drop slightly.
Free mod: remove your air filter & housing, just leave the tubing. Is that good for the engine? NO - no air filter. Shit if your that ghetto you could always put a towel over then end. Use duct tape or rubber bands to hold it on :icon16:
Distributors aint free 90CRXZCSi, well they can be if ya gank it :uhoh:
Milliardo
09-21-2003, 01:28 AM
Basically the only way you can mess the idle rev is you adjust the cable too tight, preventing cable play, which would result in your car revving high all the time. http://www.hondaclub.com.ph/archive/index.php?board=7;action=display;threadid=109;star t=0 on our discussion about throttle cable adjustment.
About adjusting the distributor housing--I've adjusted it a few times before getting the satisfactory adjustment for me. So that means moving it a few times. Would that somehow affect the timing? I mean, I've adjusted it to advanced timing, but before that put it into the maximum extent of the housing's movement before readjusting it to a better position, though the adjustment is still in the advanced position?
Bambooseven
09-21-2003, 02:59 AM
beat the shit out of your cat with a crowbar and a hammer. (just don't let the humane society hear about it)
freekinfreak
09-21-2003, 12:49 PM
Another freebie is taking off your p/s belt.That dropped my 1/4 mile time from my typical 15.5 to 15.3.And it is not that much harder to turn.
