Surging idle after motor swap?
IntegraB18LS
09-17-2003, 09:46 AM
I recently swapped in a 1995 integra ls b18b1 motor into my 1995 civic ex d16 chassie. the motor surges when it idles, what could cause this? I swapped the motor and computer over and it did not do this in my integra. I do not see any vacuum lines not hooked up. Is it possible that I just havent drove the car on the road yet? Also it idles kinda high but that might be because I havent let it fully warmed up yet.
Kyle.
Oh one more question the dash on the civic sometimes doesnt work and the last owner told me to wiggle the wires under the dash around the fuse block area for the dash to work - what wires would this be? the tach/speedo/fuel/temp dont work and I cant find the wires that made it do it - he came over and messed with it and it worked he showed me where he hits the wires but I do it and nothing.
Ace$nyper
09-17-2003, 12:06 PM
let her warm up first then write back
IntegraB18LS
09-17-2003, 02:22 PM
Okay I let her warm up and it stayed idleing around 2000rpm, I unpluged the IAC and it droped down to a nice 1000 rpm but the cheak engine light came on - is my IAC bad or is it something else that is making it idle high? It idles smooth at 2000 rpm but when you rev it is when it starts surging from - it will drop down to 1k then brings it to 2k then back to 1k back and forth for a while.
Also when I bend my fuse box the dash goes on?
90CRXZCSi
09-18-2003, 01:55 AM
was the throttle body taken off at any point? My guess is that its a vacuum leak somewhere. Well good luck to ya and i hope you can get it runnin good.
IntegraB18LS
09-18-2003, 10:21 AM
nope, i just pulled the motor/tranny and everything right out and swapped it in, didnt even take a belt off. Ill keep looking for vacuum leaks though...
Kyle
90CRXZCSi
09-18-2003, 11:04 AM
im still having vacuum leaks myself so if i find anything out, ill let ya know.
b18cguy
10-27-2003, 11:19 PM
Check your fuses for the guage cluster. I blew one of mine and the same thing happened.
joey h.
10-28-2003, 12:58 PM
there is a valve on the bottom of the throttle body. i dont know the correct term for it but it acts similar to your iac valve. it has two water lines running to it. take your intake tube off your throttle body and with the car running make sure your butterfly is closed. there should be two holes right in front of your butterfly. take your finger and stop the holes up. see if this corrects your idle. if it does let me know, i'll tell you how to fix this.
Ricochet
10-28-2003, 02:30 PM
This post reminded me that mine did the same exact thing. I didn't do anything and it went away after about a week. Sorry no technical help, but maybe just driving it around coughed up the hairball..?
1990lsvtec
11-05-2003, 01:03 PM
I had the same problem with my B18A motor. Many of my friends with B series engines have had the same problem as well, and for every case so far we have found the fast idle valve had an internal vacuum leak. It should be on the left side of your intake manifold just under the throttle body. I believe three bolts hold it, after you take it out, unscrew the twol smaller screws that hold the cap and with a large flat head screwdriver unscrew the inner part of the valve, clean it up, and re-tighten it. That most likely would be a case of your problem
Hope that helps let me know bro.
Lude_03
11-05-2003, 10:35 PM
The same thing happened to me with my Prelude, my car would rev up to 2 grand then drop to 1 then up to 2 and back to 1..... I was told it was my oxygen sensor? by the sounds of things I dont think thats it
also ....another question, when my car is warm, after i shut it off then try to start it again the fuel pump doesnt always kick in and i have to keep turning the key until it finally kicks in .... what could be causing this?...plz help me ... I am trying to sell the car but it is hard due to those problems....Thank You
B16CrX89
11-05-2003, 10:38 PM
this happened to my crx, there is a idle screw on the throttle body near the air intake u need to either loosen it up or tighten it try that an see wat happens cuz thats wat happened to me an i loosened mines up an it was fine.
jantal
01-22-2004, 01:18 PM
"there is a valve on the bottom of the throttle body. i dont know the correct term for it but it acts similar to your iac valve. it has two water lines running to it. take your intake tube off your throttle body and with the car running make sure your butterfly is closed. there should be two holes right in front of your butterfly. take your finger and stop the holes up. see if this corrects your idle. if it does let me know, i'll tell you how to fix this."
i did this and the idling stops surging. anyone know how to fix it???? help!
Smokn91HB
01-22-2004, 03:46 PM
coulds be you TPS as well. or the EGR valve check all of that, also somtimes if you run it around and run it hard a few times it could straighten up.
19B16CRX91
02-13-2004, 07:06 PM
ive been having the same problems with my 91 B16 rex, and a while ago i tried cleaning up and retightening the bolt in the idle control valve like 1990lsvtec said, and though my problem is better, it is still idling high, maybe at 1500-1700. any other ideas??
