transmission only works in low - 85 Park aveBrad McCoy 09-15-2003, 03:00 PM Additional info: Changed out modulator and flushed transmission and changed filter and new fluid. Still will not shift out of low :banghead: HEEEEELLLLLLPPPPPPPPP!!!!! Transmission will not shift out of low gear. Any ideas? thanks Brad Brad McCoy 09-19-2003, 10:35 PM Anybody out there????? Additional info: Changed out modulator and flushed transmission and changed filter and new fluid. Still will not shift out of low :banghead: HEEEEELLLLLLPPPPPPPPP!!!!! Transmission will not shift out of low gear. Any ideas? thanks Brad pappyd 02-12-2004, 01:20 AM Had the same problem - wouldn't shift out of low gear (unless you wound it up to 25 m.p.h.) Noticed there was a "kink" in my throttle cable. The quick fix was to open throttle all the way (while car was not running) and release. Cable went back into place and transmission shifted smoothly. Purchased throttle cable for $20.00 (had a heck of a time installing it) but haven't had that problem since. Can't hurt to look and see if your cable is releasing all the way back. Good luck. Automotive Network, Inc., Copyright ©2012
