No Heat?
There are Three very common problems that maybe present here.
1. Air bubbles in your coolign system: Try flushing and refilling the cooling system.
2. The Heater controls: These are vaccuum operated. Listen hard inside the car when switching from hot to cold. If indeed you can here a clunk or similar sound, the contols are fine. If not, check the vac lines for leaks.
3. The Heater core: Do you see or smell radiator fluid inside you car, on the floor boards (passenger side) Or a thin layer of slippery deposit on your windshield? If so, change the heater core, if not, take it out and inspect it / replace it.
Hope this helps.
Good luck
