Are You SIRIUS? With Your Exterra?Azideam 09-09-2003, 08:20 PM Well I got my Kenwood Excelon with the sirius tuner! Took about 2 hrs to Install Easy....I first Installed the antenna unit on the far back of the roof abou 5 inches from the edge of the metal,the distance of the tail on the antenna! I carfully ran the micro cable to the left of the back of the X In the trough for water to run off.To the left side their Is a boot that brings the wires up for the brake light.I cut a small slice In the boot and fed the micro cable through the boot and down to the left side of the car underneath the drivers side REAR 6 x 9.That Is where I placed the tuner I used velcro to attach it to the side of the truck right below the 6 x 9.The Interlink was even easier to Install I just followed It up the left side of the coach under the plastic to the dash area and up over the steering colum to the back of the deck.... Made a phone call,gave some imformation,and bingo music was on.... I bow to the people at Sirius....Good thing..... Now I can drive to work and listen to music,Instead of adds....Isnt that the way It should be???? I also used silicone to secure the micro cable In the far back of the trough,I first wiped out the trough to make the silicone stick better. Next Time!!! How I will make my 100 watt x 4 Crunch amp fit In the limited spaced Exterra.... Let The Mutating Begin..... Mutant X Schludwiller 09-09-2003, 10:52 PM Go out to the back of your truck. Look at the bottom right of your hatch. There is a sign there. Read what it says. http://www.automotiveforums.com/vbulletin/images/smilies/shakehead.gif rrdstarr 09-09-2003, 11:39 PM spaced Exterra.... Let The Mutating Begin..... Mutant X Who cares? :banghead: X-Phile 09-18-2003, 01:24 AM Go out to the back of your truck. Look at the bottom right of your hatch. There is a sign there. Read what it says. http://www.automotiveforums.com/vbulletin/images/smilies/shakehead.gif SE ? :evillol: Automotive Network, Inc., Copyright ©2012
