Blowing Oil
mrporterishere
09-02-2003, 10:11 PM
Hey people, I have a problem with my 1994 Diamante' ES. Right now, the car has about 150,000 miles on and except for two problems, it have ran fairly flawlessly since I bought it back in 1995. Here is the deal: The car has now decided that it will refuse to idle. It began to not idle once the engine warmed up, but if I turned on the A/C, the car would idle. Now, it won't idle at all. HELP !!!
The next problem is oil being blown out from under the oil cap. At first I thought the cap has just gone bad and replaced it, that did not work. I changed the PCV valve, but that did now fix the problem either. This particular problem started at around 100,000 miles. HELP !!!
Any ideas how to fix these problems ??
areho
09-14-2003, 12:27 PM
check your pcv hose and valve cover were hose connects its most likely clogged remove front valve cover run parts cleaner liquid through to check hope this helps
