Engine Swap QuestionSolReaver 04-01-2001, 09:24 AM Would the B18C5 engine change the handling of a Sol because you are moving up from a 1.6L to a 1.8L Racing Rice 09-07-2001, 01:37 PM Maybe a little in a stock Sol, but I couldnt imagine much.. Thats why you just upgrade the suspension to fix that problem.. ^YellowBandit^ 09-10-2001, 07:47 PM Nope. I thought before that the weight issue (bigger engine) would cause understeer, but it's not true. You just have to upgrade your suspension. :) dejoux 09-11-2001, 06:02 AM A B16 to a B18 has very little differnce in weight, youll never notice the difference madtownhonda 12-07-2001, 03:29 PM if your going to go 1.8...just get the short block and tranny if you want.....send your head off to portflow, skunk2 manifold, bored and tapered TB, all matched...you'll spend less and get more:D turboedsol 01-22-2002, 03:34 PM Is the H22 a better engine choice to go with over a B16? I know that the H22 has more horepower but does that make it a better choice for a sol? Or would it be better to by a B16 and spend the money that i would save making it better. Let me know b16a3sol 01-23-2002, 01:06 AM the h22a is a better choice if you want to go fast in a straight line. other than that, you will start to experience more under steer than normal, which can only be remedied with an uncomfortable suspension. unless you want a show car or one that is simply used for drag, stick to the b18 or b16. turboedsol 01-23-2002, 03:37 PM thanks that was all the stuff that i heard just wanted to clear it all up think im goin to go with a b16 Automotive Network, Inc., Copyright ©2012
