fuel filter on 94 Civicmtdxx 08-27-2003, 11:37 PM I have not looked for the filter yet, but plan on changing it soon. Would someone be able to tell me where it is located, it'll save me a little time. I am assuming it is probably near the gas tank, that is where the filter was on my old Lumina. BullShifter 08-28-2003, 02:15 AM Its actually located under-hood on the fire-wall. Little black canister with 2 lines connecting. mtdxx 08-28-2003, 07:49 AM thanks, that will save a couple minutes. sageuvagony 08-28-2003, 09:35 AM Where is the firewall? I'm sorry Ive never changed it before... But hey I have a 92 LX with now 93,500 miles and im pretty sure it has NEVER been changed. Would it help any if I changed it? should I bother? any better milage or something? Thanks in advance... I wanna change it today.. loesch8102 08-29-2003, 04:58 AM The firewall is just the back of your engine bay. If I remember right, the filter is right next to your battery. Your battery is is in the back passenger side corner right? If it is then it's right next to that. BullShifter 08-30-2003, 01:01 AM Where is the firewall? I'm sorry Ive never changed it before... But hey I have a 92 LX with now 93,500 miles and im pretty sure it has NEVER been changed. Would it help any if I changed it? should I bother? any better milage or something? Thanks in advance... I wanna change it today.. Firewall is what seperates the engine bay from the passenger compartment. Fuel filter is located left side - make sure to replace the copper washers when replacing. Release some pressure by removing the gas cap because when you remove the bolts its gonna spray. Put a rag over it or wear safety galsses. Its a good idea to replace the FF atleast every 60K - I change mine about every 30K becasue its simple and cheap. Proper maintenance is key Get yourself a factory repair manual from www.helminc.com & follow the maintenance schedule. Its recommended for a reason & the manual will walk you through each step, even pictures:bigthumb: 1 more thing(common sense) Dont smoke when working with the fuel system Automotive Network, Inc., Copyright ©2012
