Question regarding the "Netherland" settings on W203Ultraman 08-23-2003, 12:45 AM Hi, Anybody in US or Canada sets the "Netherland" settings in your 2003 W203 at the MB dealership? If so, when you lock or unlock the doors with the Smartkey, does a "Chirp" sound when you do so? Also, once you set to the Netherland setting, did your panic button work? :screwy: Mark Cummins 10-09-2003, 03:20 PM Yes It can be Done ! I Have Done Several ..Its in Version code You Will need the Star to go into the control unit to reset version code To The Netherlands Yes The Alarm will chirp when set and when Unlocked Yes You Will NOT have the Panic when its coded to the Netherlands Automotive Network, Inc., Copyright ©2012
