Previa Supercharger and driveshaftjumbojoe55 08-22-2003, 02:38 PM I was wondering if anyone knew how much supercharger oil I need to do a drain and refill for the supercharger. Also I was wondering if anyone knows if I need to put any grease into the driveshaft. I tried looking for the point for where to add the grease, but I couldn't find it. I tried looking at the U-joint as said in the Chilton repair manual, but it wasn't there. JWatson 09-19-2004, 07:09 PM Toyota u-joints on the Previa don't have grease fittings. The Supercharger will hold about 130cc's of Toyota Supercharger oil. Jeff Watson Houston,Tx. wechslerl 11-26-2004, 06:51 PM I was wondering if anyone knew how much supercharger oil I need to do a drain and refill for the supercharger. Also I was wondering if anyone knows if I need to put any grease into the driveshaft. I tried looking for the point for where to add the grease, but I couldn't find it. I tried looking at the U-joint as said in the Chilton repair manual, but it wasn't there. I did not know that the supercharger needs oil. Where do you drain it and refill it and at what intervals? Thanks wechslerl 98 SNAKE EATER 03-06-2005, 01:37 PM ttt I have a 95 S/C and wanna know the same thing.... graveler 03-28-2005, 04:52 AM ttt I have a 95 S/C and wanna know the same thing.... If you jack up the car and look behind the supercharger, there is a hex nut at the back/bottom of the S/C to drain the oil. Above to the left, there is a screw in dipstick (mine is yellow). Very tight and you need the kit with the syringe to fill the oil (about $35). Good luck. rpady 06-15-2005, 09:39 PM Buy the S/C oil at your local Chevy dealer for $8.00. Enough to do a complete refill. Automotive Network, Inc., Copyright ©2012
