4L60E Transmission question
mike-patton
08-22-2003, 12:36 PM
Will a 4L60E transmission out of a 2WD GMC/Chevy work in a 4WD GMC/Chevy? I only ask because I have a 4WD Yukon with a bad transmission and a 2WD Suburban with a 4L60E in it that I can have if it will fit.
srk73
08-27-2003, 07:52 PM
Hi Mike,
You cannot use a 2 wheel drive transmission in a 4 wheel drive truck
quiktsi
10-22-2003, 09:28 AM
Is it just me or has the 4l60e trannies just don't hold up, I have seen 7 yukon in the shop in the past month because of tranny failure,t-case, or control module.
jfarmer23
11-12-2005, 08:46 PM
Hi Mike,
I don't know about these but you used to be able to change the tail shaft. Can you not do that anymore?
yogie323
11-20-2005, 02:07 AM
These transmission do suck these are like the 700's they are delicate, extra clutches to handle the power, If all the plugs are the same it will fit and work but you will need to extend your drive shaft 4wheel drive transmissions are longer, 2wheel are shorter
birdiemaker
10-12-2007, 06:06 PM
Yes, you can. Go to http://novak-adapt.com/knowledge/4l60e.htm .
It is a site about transmissions for Jeep adaptation, but it has lots of info about the 4L60E (TH 700R).
maxwedge
10-12-2007, 08:05 PM
Welcome to AF. Please look at the dates before replying, this thread is dead, thanks.
