windshield fogging up?grncivicdhr 08-22-2003, 11:55 AM after test driving the rx-8 i noticed that the wind shield seems to fog up. has this been experianced by any other rx-8 owners and how do you deal with the problem? giwojo 08-25-2003, 01:18 AM I just bought my RX-8 yesterday and haven't experienced any windshield fogging. could have to do with weather. I am in St. louis and its bone dry here right now. I was in NY last week and the windows in my GFs camry were fogging up. If its that bad a little anti- fog will always do the trick. rgmcalpine 02-18-2004, 10:26 AM I have driven 3 rx8 in my time. I have experienced the fogging wind screen on my own car and one other test car. But it was not present in 1st car I tested. I am guessing here but I suspect that the cars have humidity from the factory which gets sealed in the car before they are transported. When the cars are transported to a cold climate the humidity starts to cause the front wind shield to steam up. You get the same effect in an older car with poor door seals. When you remove the moisture from the car the effect disapears. After a weeks driving I noted that there was sufficient quantity of water on the rear window to bead. I removed this water with a cloth and after that the car stopped steaming up. I do also run the heating system with hot air to the wind screen and feet. Press the mode button on the heater controls and you will see the display change to various options. Dont worry about this problem its short lived. I have to be honest at first I thought I was getting too excited driving the car! Jermonsta 02-21-2004, 06:46 PM LOL, what causes could there be for windshield fog..................................... wwest 03-02-2004, 04:21 PM we have a 2003 nissan quest, when two adults and four children get in the car the interior foggs up and it is difficult to clear up. Van has been to dealer already, they found no problems, used ac with heat, read manual with their suggestion, still didn't help. this problems only happens in the cold weather. any help or suggestions would be greatly appreciated. Anybody incounter this problem also? Given that your vehicle is of Asian/Japanese origin the climate control system is most likely of NipponDenso, Denso USA, design. With the change-over to the new less efficient non-freon refrigerant several design changes were deemed necessary. First, the A/C cooling evaporator, heat exchanger, was made a lot more dense and complex. The more chilled surface area for the air to flow over, the higher will be the efficiency of the heat transfer. The second issue is more directly pertinent to your problem. The slower the air flows over the evaporator's cooling surfaces the more it will be cooled and the more it is cooled raises the likihood that it will be simultaneously DEHUMIDIFIED. Another benefit of the lowering of the incoming airflow rate is better MPG, something I'm sure the automotive manufaturers haven't over-looked. Almost all modern day passenger vehicles are very well sealed against atmospheric outflow for these reasons. The way NipponDenso has chosed to keep the evaporator airflow as low as possible is by restricting the cabin atmosphere OUTFLOW. The result of that is that during the cooler months it will be really easy for the passenger cabin to become extremely humid, so humid that the windows and windshield interior surfaces, cooled continously by exposure to COLD outside atmosphere, begin to fog over. My suggestions... If it is possible to completely disable the A/C during the winter months then do so. My 01 RX300 has C-best options which allowed the dealer to "unlink" the automatic operation of the A/C in both "normal" and defrost/defog/demist modes. ON a previous 92 LS400 I fooled the system into thinking the OAT was below 32F by adding a resistor in series with the OAT sensor. I have also, on occassion, simply disconnected the A/C compressor clutch electrical circuit. My 01 Porsche has a switch added within the glove box that does that. If you park the vehicle inside it will help to leave a window or windows open so the cabin can more completely dry out. During A/C operation the ~10,000 square inches (92 LS) of evaporator surface area will become saturated, clogged, with mositure and while much of that will drain away via the provided drain a lot will remain and then evaporate into the A/C plenum and thus into the passenger cabin at the first start of the system blower. My most common occurance of intermittent and spontaneous windshield fogging was about 5 miles into my morning trip to the office during the cooler months. That instance was cured, mostly, by leaving the windows slightly open during the night in the garage. Another instance is that the A/C compressor will oftentimes shut down spontaneously, without any indication to you, if the OAT declines to near or below freezing. A few minutes after that happens the condensed moisture remaining on the evaporator will begin to evaporate into the airflow entering the passenger cabin. Be VERY CAREFULL, this can be a very HAZARDOUS situation. If you are traveling in a colder climate and begin to see wisps of condensation on the interior surface of the windshield DO NOT ACTIVATE the defrost/demist/defog function before you turn the system heat all the way to MAX! Those wisps of condensation might be indicative of the A/C compressor having previously shut down due to low OAT and now if you activate the defrost/defog/demist function the COLD windshield will become suddenly opaque from condensation due to the moisture bomb building up with the A/C plenum. The best procedure to use if you sense that the humidity is to high within the passenger cabin is to lower the rear windows slightly and quickly purge the humid atmosphere from the cabin. While I remain a strong advocate of the use of A/C to dehumdify the incoming cabin airflow and thereby help to remove windshield condensation and prevent it's formation, I don't understand why, other than the slight discomfort one might feel, the defrost/defog/demist airflow isn't also HEATED. Wwith Outside Air Temperatures, OAT's, below about 55F it is impossible to predict whether or not the the A/C can be efficient enough to be of any help. The A/C's dehumidifcation efficiency is a function of the relative humdity of the incoming airflow. The lower the temperature of the incoming airflow the lower is the probability of efficient dehumdification by the A/C until at about 35F it is practically non-existent. Automotive Network, Inc., Copyright ©2012
