Remote Buick Park Ave 1991
Sandvik
08-21-2003, 11:31 AM
Does anyone know how to program a new remote for a 1991 buick park avenue?
tman
08-21-2003, 04:09 PM
right here:
http://www.automotiveforums.com/vbulletin/showthread.php?t=129822
Sandvik
08-26-2003, 01:57 PM
right here:
Where is the Data Link Connector located?
tman
08-26-2003, 05:33 PM
look under your dash, right above the accelerator pedal. there is a black connector there, it is your DLC.
Sandvik
08-27-2003, 02:07 AM
I found a black connector, but there are only 12 pins in it, not 16.
Which pins should i jumper?
tman
08-27-2003, 07:13 AM
Ok. I have some instructions here, I'll scan them later
Sandvik
09-16-2003, 05:49 AM
I got some instructions from those who sold the remote control.
Goes like this :
1. Turn ignition switch to OFF.
2. Jumper ALDL Connector terminal A to G. Door locks lock and unlock.
3. Press UNLOCK button on one transmitter. Door locks lock and unlock.
4. Repeat step 3 using other transmitter. If only one transmitter is beeing used, go to step 5.
5. Disconnect jumper from ALDL Connector.
We have tried to jumper terminal A to G, but nothing happens....
Does anyone of you know why?
Any ideas?
Thanks!
Sandvik
tman
09-16-2003, 07:08 AM
I'm having the same problem with my 94, sorry I havent scanned my instructions, I completely forgot!
Sandvik
09-16-2003, 09:11 AM
Hi tman!
I checked with an another mechanic, at a GM (Saab/Opel)company.
He said that my programming instructions was OK for a Buick Park Avenue 1991.
And he told me that I should try to put the ignition key in the Radio-position, not the Off-position, I did so, but no luck, so I went to my regular mechanic and asked him to connect my ALDL-connector to his computer.
He programmed the computer to fit my car, and he got a message saying something like "no errors reported" so the connector seems to be working...
If I am able to solve this problem I will let you know how.
Thanks!
Sandvik
tman
09-21-2003, 12:47 PM
[ 1][ 2][ 3][ 4][ 5][ 6][ 7][ 8]
[ 9][10][11][12][13][14][15][16]
Have both transmitters present
jump terminal 8 to 4, doors lock and unlock
press unlock on one transmitter
press unlock on other transmitter
remove jumper wire
test remotes
That worked for me!
Sandvik
10-03-2003, 12:25 PM
remove jumper wire
test remotes
That worked for me!
Well, I dont have a 16 pins connector, mine has only got 12 pins.
Maybe the 1991īBuicks exported from USA to Europe was different from the Park Avenues in the US.
However, I solved the problem by moving over the cicuitcard with the radiotransmitter from the old remotecontrol to the new one.
I also moved the tape vith the three contactplates attached.
Well my remote is working perfectly now !
I know that this is not the right solution, but my remote is working OK
Thank you for youre help
Regards
Sandvik
