TodCraig Tassone 08-19-2003, 09:33 PM My TOD check light came on. I've only used the 4wd system once,months ago. Why would the light come on now ? I drove to a meeting, the Trooper sat for a couple of hours then on the way home the tod check light came on. Any ideas as to what may have caused this? rodeo02 08-21-2003, 05:06 AM Sounds like your shift on the fly actuator may be sticking (vacuum actuator, drivers side front axle). You should manually turn 4x4 on/off once or twice a month to keep the SOTF actuators from sticking. Could try to give it a tap with a mallet, or remove, clean up/replace the SOTF actuator. G/luck Joel Automotive Network, Inc., Copyright ©2012
