tires
madhouse
08-17-2003, 12:17 AM
I Would Like To Know If A 265 75r 15 Tire Will Fit On My S10 4x4what I Read On The Specs It Should Be The Same As 31 10.50 15. Any Help Would Be Appreciated.
Cy@tirerack
08-18-2003, 08:14 PM
It will vary slightly depending on the tire but most 265/75-16's will be very close in size to 31x10-15's about .1" taller and about .3" narrower.
What year and trim is your truck? 2WD or 4WD?
madhouse
08-18-2003, 11:32 PM
IT IS A 1996 4X4 EXT CAB. 6.5 OR 7" RIMS NOT THE ZR2.
Cy@tirerack
08-19-2003, 11:25 AM
31x10.5-15 will fit on your truck so 265/75-15 will probably fit on your truck as well. Both sizes will require at least a 7" rim so double check your rim size by looking for a 15x7JJ marking on the front of the rim near where the tire meets the rim or by taking off the tire and looking at the back of the rim.
