no brakestomintegra123 08-16-2003, 08:18 PM hello, I just changed my 1995 acura integra brakes (front and rear), but after changing it, the brake pedal sinks to the bottom everytime I stepped on it. In other word, there's no brakes. I checked to see if the brakes are pushing into the pads by stepping on the brake petal after changing my pads, but I have no clue what is happening. The device that pushes against the brake pads works fine. Could it be the brake system that needs to be looked at? I changed my brake pads many times before without any problems, but this time, it didn't go right for me. Also, the brakes works fine before I changed it other than the squeeking noise, which was the reason I changed it. Can anyone help me with this problem before I bring it to the shop. Thanks in advance. BullShifter 08-17-2003, 01:10 AM Have you tried bleeding the system? T-Mo 08-17-2003, 01:46 AM I would say the same. Check your brake fluid and bleed the system. tomintegra123 08-17-2003, 03:38 PM Thanks for all yur responses. I will bleed the brakes. Hopefully, that is the problem. Automotive Network, Inc., Copyright ©2012
