I'm looking at a 99' neon with 73,000 miles? Its in awesome condition but is that too many miles? How many miles will I expect do get out of it that it will run nice? Please help guys, I'm going to check this car out 2marrow so I need answers quick! Thanks
I've heard of people reaching 200k.Its just keeping up maintance on it and you should be ok.If the body is good u can always rebuild our new engine 2.0,2.4 or 2.7L
98PlymouthNeonExpressoATXDOHC
Mods:
iceman coldair intake,af/x underdrive pully,mp/x 60mm TB,ported intake manifold,performance valve body,performance overhaul kit,alabama boss hogg 3k convertor,moroso transmission cooler,fiberglass z-3 fenders........to be continued ER
My '95 has 92K, the '96 has 110K, and my stepdad's '98 had 135K before he traded it on an '03 SXT. They all run perfectly, and they have all been serviced fairly regularly.
If the car you're looking at is well taken of, it should go at least another 100-200K easy, depending on how it's driven. If it doesn't, Neons are cheap and easy to fix.
<~~~156K and still ticking on the '97. Are you buying from a dealer or private party? If private party, ask them to provide you with all the maintainence records. If not already done, it will need a new timing belt and water pump. May need new plugs, plug wires, brake pads....of course depending on when this all was last done. Like already mentioned if the body is good and interior is nice too you can always build up the motor or do a swap.
