1st gen Neon diagnostics codesKatWoman 08-13-2003, 05:53 PM Since the Check Engine light is a pretty common occurrence (or curse) for us Neon owners, here's a list of the diagnostic codes and to get them when your light goes on....or if you do a random check :D *Mods can this be stickied for a bit? __________________________________________________ __ ON-BOARD DIAGNOSTICS 1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on. 2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32. A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition for a neon. CODE Description of Trouble Code 11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking 12 Direct battery input to PCM was disconnected within the last 50 key-on cycles 13 No change in MAP from start to run 14 MAP sensor voltage too low 15 No vehicle speed sensor signal 17 Closed loop temp not reached or engine cold too long 21 02s sensor problem (oxygen sensor), upstream or down stream 22 Engine coolant temp sensor out of range 23 Intake air temp sensor out of range 24 Throttle Position sensor out of range 25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found 27 Injector control circuit 31 Evap purge flow monitor failure or evap solenoid circuit 32 EGR system failure 33 A/C clutch relay circuit 34 Speed control Solenoid circuits 35 Rad Fan control relay circuit 37 Torque converter clutch solenoid CKT or park/neutral switch failure 41 Generator field not switching properly 42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles 43 Multiple/ single cylinder misfire 44 Battery temp sensor volts out of range 46 Charging system voltage too low 51 Fuel system lean 52 Fuel system rich 53 Internal control failure 54 No Cam signal at PCM 55 End of error messages (If you get this only, no errors were found) 62 PCM failure SRI mile not stored 63 PCM Failure EEPROM write denied 64 Catalytic Converter Efficiency Failure 65 Power steering switch failure Automotive Network, Inc., Copyright ©2012
