95 Bonneville stereo unlocking code
JLFON9
08-12-2003, 04:56 PM
Hello, does any one know how to unlock the stereo of a pontiac bonneville 1995 edition, i just got the car and the stereo its locked, dont have the owners manual, can any one tell me please how to unlock the stereo...
Thanks in advanced..
Flatrater
08-12-2003, 07:16 PM
Check your PM box I sent you directions on what to do!! Yes their will be a charge but hopefully it will be a small one and then you will have your unlock code!! Please write this unlock code down so in the future you won't need to pay to have it unlock.
Here is how to get the back up code, just take the numbers to a dealer with the car!!
Obtaining the Radio Display Code (Scrambled Backup Code)
Perform the following steps in order to obtain the radio display code:
Important
In order to display this code, the radio should be in the LOC mode or have SEC displayed before proceeding.
Press and hold the pushbuttons 2 and 3 for approximately 6 seconds until the first 3 digits of the display code are displayed.
Write the numbers down.
Press the AM-FM button. The second 3 digits are displayed.
After approximately 5 seconds or if another button is pressed the display returns to LOC. The display code must be unscrambled in order to acquire the factory backup code that unlocks the radio.
Flatrater
08-12-2003, 07:20 PM
Here are some other things you might need in the future!!
Unlocking the Theft Deterrent Feature After a Power Loss
Enter the code as follows pausing no more than 15 seconds between steps:
Ensure LOC appears when the ignition is turned to the ON position.
Press MIN and 000 will appear on the display.
Press MIN again in order to ensure the last 2 digits agree with the code.
Press HR in order to ensure the first 1 or 2 digits agree with the code.
Press AM-FM after the secret code has been confirmed. The display will show SEC indicating the radio is now operable and secure.
If the wrong code was entered 8 times, INOP will appear on the display. Turn the ignition to the ON position and wait an hour before trying again. The customer will have 3 more chances to enter the correct code before INOP appears.
Disabling the Theft Deterrent Feature
Enter the secret code as follows pausing no more than 15 seconds between steps:
Turn the ignition to the ACC or RUN position.
Turn the radio OFF.
Press and hold the 1 and 4 buttons together until SEC shows on the display.
Press MIN again in order to make the last 2 digits agree with the code.
Press HR in order to make the first 1 or 2 digits agree with the code.
Press AM-FM after the secret code has been confirmed. The display will show -- -- -- indicating the radio is no longer secured. SEC will appear on the display if the code entered is incorrect. The radio will remain secured until the correct code is entered. The radio will not turn on and LOC will appear on the display if battery power is given to a secured radio.
Zbyte13
08-29-2003, 07:01 PM
I have the same exact problem, but what do you mean when you say the code must be unscrambled? What would I have to do to unscramble it?
Never mind. Figured it out after searching on google for a while. I'll just quote what I found on unscambling it.
Call 1-800-537-5140. You'll be asked for a dealer code, and the one I have from the forum is 202107; I have also heard that 139010 will work. You may need another if they ever disable this number. Enter this number and then press the pound (#) button.
The 202107 number didn't work for me so just use 139010.
daman
08-29-2003, 10:05 PM
Hey Flatrater,sent ya a PM did ya get it???????????????????????????????
