dodge colt 1995 ......
alian2001
08-07-2003, 12:56 PM
Hi, I have dodge colt 1995 ......
This car do not start. The motor turn to start, but nothing happens.
I check for missfire, but the fire is present on spark plugs. so the problem is at a another place .
It come very close to start,,, It look like if has missfuel.
Do you have idea....
new wires, plugs, cap, rotor, fuel filter ,are on it
Thanks...
Richard.....
sorry for my english
Polygon
08-07-2003, 03:36 PM
Could be your starter.
PWMAN
08-07-2003, 09:07 PM
Only if it's not cranking the engine fast enough.
He could not be getting fuel, possibly a bad fuel pump. What knid of fuel injection does this car have? Multi port or TBI?
alian2001
08-08-2003, 02:49 PM
HI.
I know the problem is not fuel pump, because I have tested it. and it was ok.
could be map sensor or temp sensor?
Thank,,,,
Richard...
pcv
08-10-2003, 08:56 AM
It is quite possible that you may have a problem with the coolant sensor. These import engines have tempermental coolant sensors. However you need to scan the system to verify the problem. Any way the sensor is not very expensive. I'd throw one in and keep my fingers crossed. Do not flood the engine by cranking it continually. Good luck.
MoparMan69
08-28-2003, 08:33 PM
Thanks...
Richard.....
Going by this post, have you made sure that the timing is correct? Meaning: be sure that the distributer is not 180 degrees out of time, has the distributer ever been removed? Timing belt replaced recently? This could be a timing issue, you don't say what type of engine you have, I have a 1987 Dodge Colt Vista, the belt was so worn that it jumped a couple of "cogs" of the belt and the timing was off enough so as not to be able to start it, it would fire once in awhile or try to start but never would.
Had to install a new timing belt, I put in the whole kit on my 2.0L, main belt, balancer belt and tensioner pulleys. I'm not saying that this is your trouble but it sure sounds like what my colt did to me.
You can remove the plastic covers that protect the belts and have a look at them, your engine might use a chain, not a belt, goodluck to ya:)
