Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nonspecific
Old 08-07-2003, 11:40 AM   #1
sixpackbird
sixpackbird
1995 Monte Carlo ABS Diagnositcs
Does anyone know which scan tool should be used to check the ABS on a 1995 Monte Carlo Z34? I have an OBD 1 Scan Tool and it seems to check only the powertrain components and it states that there are no faults. The emission label states the car is OBD 1 compliant, however, Chiltons says the 3.4l engine is OBD 2, but the connector on the car is the OBD 1 connector. My yellow ABS light is on, and I'd like to figure out what is wrong. Is there a different ABS diagnositc connector other than the OBD 1 connector under the IP? Does the diagnosis require a different scan tool? Any advise on how to fix this would be greatly appreciated.
sixpackbird is offline   Reply With Quote
Old 11-30-2003, 02:43 AM   #2
av8rdavid
av8rdavid Normal reputation
Angry Same problem!!!!
Any idea what scan tool to use for ABS on a 95 Z34 monte?
ABS light on and abs brakes inop....
HELP!!!!!!!!!!Winter is coming and that means snow!!
av8rdavid is offline   Reply With Quote
Old 01-14-2004, 02:59 PM   #3
muskoka00
muskoka00 Normal reputation
Re: 1995 Monte Carlo ABS Diagnositcs
Same problem with 3.1, can not find problem, all mechanical parts are OK.
muskoka00 is offline   Reply With Quote
Old 01-14-2004, 05:07 PM   #4
av8rdavid
ABS scan tool
A member of this forum e-mailed me important information reguards the abs system...Turns out the system can be scanned with a TECH II GM scan tool to check what and where in the system there is a failure which causes the light to remain ON thus shutting down the entire ABS feature.
This tool is not cheap, you can't get one at JC whit. because the cost is aprox. $4000-$5000!!!!
Thats why a dealer will charge you about 100 bux (a fraction of the cost of the tool its self) to scan your car.After the scan you'll be able to pinpoint where the problem is and what to replace/repair.
Hope this helps!
Dave
Old 01-17-2004, 11:49 PM   #5
comp
comp Normal reputation
96 when ODBII came abs may have a seporat port, not sure
comp is offline   Reply With Quote
Old 01-18-2004, 03:20 AM   #6
av8rdavid
ABS scan
Yes, the ABS (from what i believe) has a separate port..
Old 01-28-2004, 05:00 PM   #7
muskoka00
Tks, will look.
Bookmarks
Google
Web AF
