Honda Accord Specifications
Gogeta195
08-06-2003, 11:47 PM
What are the specifications of the 1995 Honda Accord LX? (HP, Torque, MPG)
What are the different generations of the Accord and their specifications that I listed about?
BullShifter
08-07-2003, 01:40 AM
95 accord lx data (http://autotrader.com/research/model_info/modelinfo_technicalspecs.jtmpl?vehicle_number=U129 23&x=44&make=260&model=Accord&year=1995&restype=used&y=6&ac_afflt=none)
MPG dont mean anything
euroAccorDeuro
08-07-2003, 12:53 PM
Can somebody give me the link for the 90 accord lx please? My computer is f'ed up and those dropdown lists dont work.
00accord44
08-07-2003, 01:15 PM
Miles Per Gallon last time I checked:wink:
BullShifter
08-07-2003, 08:58 PM
besides that
accordztech
08-08-2003, 01:29 AM
90lx
Manufacturer Code No Data
Wheelbase 107.1
Overall Length 184.8
Vehicle Height 54.7
Vehicle Width 67.9
Front Headroom N/R
Front Legroom N/R
Curb Weight 2,857
Gross Vehicle Weight N/R
Seating Capacity 5/N/R passengers
Payload Capacity N/R
Towing Capacity N/R
Final Assembly Location N/R
Brakes
Mfr. Code Description
Brakes, Power Disc/Drum Std
Drive
2 Wheel Front Drive Std
Engine
Engine, 2.2L 4 Cylinder 125 hp Gas
* Cylinder Number: 4
* Valves per Cylinder: 0
* Cylinder Configuration: In-line
* Compression Ratio: 0
* Camshaft: SOHC
* Engine Size: 2.2
* Engine Type: Gas
* Coolant Capacity: 0
* Oil Capacity: 0
* Stroke: 3.74
* Bore: 3.35
* Horsepower: 125 @ 5200rpm
* Torque: 137 @ 4000rpm
* Fuel Capacity: 17
* Fuel Type: Unleaded Regular
* Fuel Delivery Type: Multi-Port Fuel Injection
* Fuel Delivery: Multi-Port Fuel Injection
Std
Sound
Radio, AM/FM with Cassette Std
Steering
Steering, Power Std
Suspension
Suspension, Wishbone/Coil Spring/Coil Spring
Std
Transmission
Transmission, 5 Speed Manual OD
* Type: Manual
* Speeds: 5
* Overdrive: Y
* Gear Ratios:
1st Gear: 0 2nd Gear: 0
3rd Gear: 0
4th Gear: 0
5th Gear: 5
6th Gear: 0
Reverse: 0
Final Drive: 0
* Torquelock: N
* Heavy Duty: N
* Std Gross Vehicle Weight: 0
* Max Gross Vehicle Weight: 0
* Curb Weight: 2857
Std
Transmission, 4 Speed Automatic OD
* Type: Automatic
* Speeds: 4
* Overdrive: Y
* Gear Ratios:
3rd Gear: 0
4th Gear: 4
5th Gear: 0
6th Gear: 0
Reverse: 0
Final Drive: 0
* Torquelock: N
* Heavy Duty: N
* Curb Weight: 2963
Opt
Fuel Economy (city/hwy)
Transmission, 5 Speed Manual OD 24/30
Transmission, 4 Speed Automatic OD 22/28
accordztech
08-08-2003, 01:33 AM
my car says 29/24 mpg. how do i determine my MPG. usually i get 300 miles a tank..thats city...i fill up with at least 15 gallons...
if its that bad ill change my fuel filter.
