1995 cadillac serpentine belt tention
Google
Web AF
magic8161
08-05-2003, 10:14 PM
how do you put the belt on? how do you pull back that spring pully? i tried a screw driver and i broke a few teeth in the plactic pully will this hurt the belt? helpppppp....Jimmy
charleylol
01-08-2004, 12:47 AM
I had a 1994 Deville with a 4.9 and now have a 1999 Deville with a 4.6 Northstar engine. Both of these tensioners are pulled back by using a 3/8" drive strong bar from your ratchet set. You need lots of leverage. Look for the square hole in the tensioner arm as viewed from the passenger side fender area. The belt will probably slide into place best if you route the belt around all other pulleys and then the pulley with no locator edge last while having a friend pull the strong bar and tensioner.
As for the broken vanes on the plastic pulley; the pulley will probaly have a short life. It will be weakened and off-balance. It is fairly inexpensive and should be replaced now; not on the highway. Try Auto Zone.
Google
Web AF
