Keyless Entry 1994 YukonMYT30TH 08-03-2003, 11:24 AM Any help regarding infomation on reprograming a new key fob would be greatly appreciated :smile: I did a search and have tried different procedures listed but have not had any luck :frown: It has the Goodwrench keyless entry/alarm system if that helps. Thanks in Advance !! Bas_GMC 12-29-2003, 05:07 PM Any help regarding infomation on reprograming a new key fob would be greatly appreciated :smile: I did a search and have tried different procedures listed but have not had any luck :frown: It has the Goodwrench keyless entry/alarm system if that helps. Thanks in Advance !! 1. Short pin 4 and 8 on the DLC (Data Link Connector) After about 2 second the locks will respond with a cycle (close - open) 2. Press and hold the locjk and unlock button on the first transmitter you want to program, until the locks cycle (about 10 sec) 3. repeat step 2 for each remote (up to 4) 4. remove the short on pin 4 and 8 5. TEST OPERATION The DLC is located under the steering wheel. Bas Automotive Network, Inc., Copyright ©2012
