Rodeo not starting when HOTtoddco 08-01-2003, 10:23 PM When my Rodeo is hot, after running for a few hours on the highway, or around town driving in 95+ weather, it won't start. It will crank and crank and crank! But what it will not to is start! I think it is the fuel pump - but has anyone else seen this? ~Todd frosty024 10-17-2003, 05:22 AM what you've got there is a worn Crank Sensor. I've had this happen. It shuts off hot, and won't start back up right away. but after a cold soak, it starts back up again. relatively inexpensive part. but it's the labor that'll get ya. paulsantangelo 12-11-2004, 04:05 PM Hi there: Did this correct your problem, I'm having the same trouble. Seems it occured after I replaced my distribiture cap. what you've got there is a worn Crank Sensor. I've had this happen. It shuts off hot, and won't start back up right away. but after a cold soak, it starts back up again. relatively inexpensive part. but it's the labor that'll get ya. Automotive Network, Inc., Copyright ©2012
