07-31-2003, 12:44 PM
Turbo on Galant GSX
My question is this. I am building a turbo motor for my GGSX; however, I still have not gotten a straight answer as to how strong the stock drivetrain is. Also, does anyone know if I would be able to put a DSM tranny in with the stock rear end or would/ could I change that, too? Thanks in advance. -Jaysin
Today is the greatest...
08-01-2003, 03:02 PM
Dunno why you'd want to. The Galant GSX tranny is the exact same as the GVR4 tranny. And it also has the turbo flywheel. The GVR4 tranny is the preferred swap for DSMer's , because of the taller 1st gear. The rear end is only a 3-bolt , so you may wanna change that to a 4-bolt. I'm also planning on changing my hubs to 5 lug. 4 lugs is no good for drag-racing , IMO.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
08-01-2003, 09:16 PM
Are you absolutly sure about that? I would think being an NA it would have different gear ratios, but if you're 100% that's cool. I'd like that to be true.
08-03-2003, 04:11 AM
One thing about the Galant GSX's is they use the NT 4G63 , but with a 5 spd only. There are no Galant GSX auto's. Normally DSM's have 2 different tranys from the T to the NT cars , even in manual , but not in this case. The NT flywheels are bigger and heavier than the Turbo flywheels , you can tell by the bellhousing size. The Galant's were made in Japan , not the US , so they got all the same stuff as the VR4's , including the tranny , with some minor noteable exceptions. No Active ECS (suspension) and no AWS. But everything else is the same. I've driven both a 1st gen Eclipse and of course my own Galant , back to back , and I know for certain the GSX's tranny has a higher first gear. Its good to almost 20 mph , while the shorter geared Eclipse tranny is barely good to 10. See where you redline at in first gear , and if you've ever driven a 1G , you'll know what I mean. To my knowledge , and I've done some research , the GGSX was not a "variant" of the GVR4 , but rather just a non-turbo counterpart with all the same stuff installed. Its only the American versions that wasted time with installing weaker trannys in NT cars , Mitsubishi Japan had no such hangups. It makes more sense tooling and production cost-wise also , something American manufacturers have no clue about.
Sorry for the tirade , but I'm absolutely sure the GVR4 and the GGSX have the same tranny.
08-04-2003, 10:04 AM
That's great, man. Thanks a lot.
09-02-2003, 11:31 PM
Re: Turbo on Galant GSX
The Galant GSX has a different final ratio. You will kill your rear diff if you put in a Galant VR-4 or DSM tranny in.
http://www.vfaq.com/mods/Trannies.html for more info.
and RockinWRX, why are 5 lugs better for drag racing? I don't understand the logic behind that.
drew
Galant VR-4 #872/1000
And yes, I'm 100% sure about the tranny/ratios.
09-03-2003, 12:17 AM
Lol...hahahahah.....oh no, only four lugs.....I hope my wheels don't fall off. Back in the early 90's when Mitsu rallied the gvr4 they used the same four lug hubs. Worked fine for them....works fine for me.
Mark
12.78@106.43
09-03-2003, 01:57 AM
Re: Re: Turbo on Galant GSX
drew
Well whatever , I was planning on using a DSM LSD rear anyway. And a Shep-built DSM tranny with the the double synchros and the taller GVR4 1st gear. Don't really want an open diff back there for drag racing. And 5 lugs are stronger than 4. Everybody knows that. I'm switching my front and rear hubs to DSM 5-bolts. Only Honda's run 4-bolt.
09-04-2003, 01:27 AM
Re: Re: Re: Turbo on Galant GSX
Ultimately, you were giving bad advice that would have cost this other guy the need to get a new rear end. That ain't cool, trying to play it off as if it wasn't any thing.
Anyways, none of the 11 sec galants run 5 lug hubs. I have 5 lug hubs on my GVR4, but only because I had the parts lying around, and not because I needed the extra lug to hold a rim on.
Oh BTW, RX7s, and 240SXes also ran 4 lug hubs.
09-04-2003, 02:04 AM
The only reason I would ever switch to five lug hubs is because it's easier to find wheels wider than 7.5" in that bolt pattern. Most wheels using a four bolt pattern only come in widths up to 7.5" which limits how wide a tire you can run. It has nothing to do with strength, but I'm sure Rockinfucktard has other reasons.
Mark
12.78@106.43
09-04-2003, 02:20 AM
Actually , if you knew anything at all about swaps , most people go for the 5-lug hubs , if they were available on a similar model. For instance the S14 Silvias come with 5-lug hubs , and most tuners choose to swap those in. S13's came with 4 lug , typically. Its is a lot stronger than 4 lug hubs , and the extra margin of safety if one breaks during a hard launch or extreme cornering. Maybe you guys need to read SCC or Turbo or Super Street and get a clue how the real tunerz do things. I so hate backyard mechanics that don't have a clue.
09-04-2003, 02:39 AM
How about you shove your five lug hubs up your ass. Guys do the swap for more brake options and wheel options...not for strength. Something else will break long before the lugs do dumbass. I pull consistent 1.7 60' times at the track and don't have any problems whatsoever with my four bolt hubs. If anything an axle would go first.
You're so ignorant it's not even funny. Read SCC, Super Street or Turbo?! Are these your so called "factory repair manuals" you've been spouting BS information from. Even in SCC when doing the five lug swap on their "project silvia" it was for the option to install 300zx brakes..not because they were worried about a wheel falling off because of one less lug.
You do realize now that you have proven yourself a complete tool on this site throughout all these BS posts and threads you've written and nobody is going to listen to you.  With every post you write you only make it worse on yourself.....
Mark
12.78@106.43
09-04-2003, 02:57 AM
Damm , you can only get a 1.7 60 foot time. I grab 1.5's in my WAGON all the time. And its pretty close to stock. Oh yeah , and 5-lug hubs.  And I have factory manuals for a few cars , guess that what happens when you are a real tuner. Plus I subscribe to all 3 mags I mentioned , so I don't get left behind like you obviously have. How many times did you get left back in 2nd grade?  So far the only tools I've met on this site has been the GVR4 crew. Guess I'm not hangin with you rejects anytime soon. I wouldn't soil my image by doing so. So when I'm running 10's , I won't be claiming membership in your sorry little .org. Funny how Ive never seen it mentioned in the DSM.org clubs , of which I am a member. All the GVR4 guys here are members of the local DSM club. So I guess your little .org is not a recognized body. Which makes you all
Don't worry , I'm not posting in this thread anymore. Don't wanna get my hands dirty. I think you guys have something contagious...........
09-04-2003, 03:07 AM
Hahahahah....you stupid fuck....1.5 60's in your stock wagon my ass. You got any video for proof of this BS? I didn't think so. And let me tell you something about being left behind......that would be YOU trying to chase my car. You come back now when you're running 10's alright. I gladly invite you because I'm sure without a doubt that will never happen.
Mark
12.78@106.43
09-04-2003, 05:50 AM
Dude please just shut the fuck up. You are so stupid and so damn disrespectful.
Rice rocket.
