egr info i found
robbyaube
07-30-2003, 12:23 PM
here is some good info i found on cleaning egr ports.
http://www.tech2tech.net/T2T_TSB/T2T013.pdf
rob
bckwld03
07-30-2003, 01:18 PM
pretty informative thanks for puttin up the link, now i wonder if they have 1 of those articles for the h22
92lx
07-31-2003, 12:39 AM
Great info! thanks!
vassil3427
07-31-2003, 10:40 AM
Just a quick question, I've never cleaned my egr ports before( I have a 1997 Accord I4) wouldnt that gunk get sucked up into the engine? Would it hurt anything?
NorCalRacer1
07-31-2003, 10:59 AM
to answer your question, no it wont hurt your engine. its more of an "emissions" concern. nothing will get sucked into your engine that will do damage as a result of these plugs being clogged. i say leave em clogged, who wants exhaust running back into thier intake anyways, or you could make an EGR block off plate, or just un hook the vacuum hose to the EGR valve and cap off both ends.
vassil3427
07-31-2003, 12:30 PM
Well I think I'll just clean then out, I like my car running the way Honda designed it, I dont think it would run right if you unhooked the vaccum to it....
robbyaube
08-01-2003, 12:31 PM
i was looking at my motor an counted what i thought to be the egr ports but there are only 6, is that normal or are there two that i cant see.
rob
Hondafan96
08-02-2003, 12:17 AM
So clean them or no?
loesch8102
08-02-2003, 01:47 AM
Yes, clean it. During normal cruising throttle position the car will have a very lean Air/fuel mixture, thus raising the temperature of the combustion chamber. If this temperature gets too high it could create a pre-ignition situation which is bad on just about everything. The EGR system is not active during full throttle or idle conditions so I don't understand why anyone would disable it anyway.
robbyaube
08-06-2003, 03:56 PM
so how many egr's are there in my accord 91, if anyone knows? there are what looks like 6 but i was thinking maybe that there are only 4 because there are 4 in line then two other things that look the same but are not in line maybe those aren't.
robby
