programing gm remoteslockdog 07-27-2003, 04:14 PM need to know how to program gm remote, are they all pretty much the same like the ford. if not please tell me if you know how?:bloated: JeffL. 12-10-2003, 10:30 AM I found this from another post on this website. Might try it on yours??? Important! Once the BCM enters program mode, all transmitters must be programmed at the same time. Any transmitters not learned at this time will be erased. 1) Remove the key from the ignition cylinder 2) Remove the BCM PRGRM fuse from the fuse panel 3) Close all the doors 4) Close the liftgate 5) Turn the ign lock cylinder to the ACC. position 6) Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second 7) Open and close any door Achim will be heard when the system enters the BCM programming mode IMPORTANT! After 7 seconds a chime may be heard confirming successful synchronization. It is necessar to wait approximately 14 seconds for a second chime that will confirm successful programming. 8) Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds 9) Repeat the previous step on each additional transmitter to be programmed. 10) Remove the ignition key from the ignition cylinder 11) Install the BCM PRGRM fuse back into the fuse panel. Automotive Network, Inc., Copyright ©2012
