Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Old 07-27-2003, 12:14 PM   #1
t359
t359
No fuel to carb.
Can't get fuel up into carb and therefore, engine won't run. Replaced fuel pump, but no help. Where else should I be looking? All started when I was charging AC. Engine stalled out and hasn't run since. All fuses and fusible links are good. Tank gauge sending unit indicating 3/4 full. Scratchin' my head. Thanks!
t359 is offline   Reply With Quote
Old 07-27-2003, 01:27 PM   #2
2strokebloke
In Stereo where available
2strokebloke's Avatar
2strokebloke +3502strokebloke +3502strokebloke +3502strokebloke +3502strokebloke +350
How long has it been since you replaced the fuel filter?
Support America's dependence on foreign oil - drive an SUV!
"At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald.
If you find my signature offensive - feel free to get a sense of humor.
2strokebloke is offline   Reply With Quote
Old 07-27-2003, 02:42 PM   #3
t359
t359
Engine stalled, can't re-start
Fuel filter is fine. There's no fuel making it up the piping from the fuel pump. Fuel pump is brand new.
Old 07-27-2003, 09:00 PM   #4
jeffescortlx
jeffescortlx Normal reputation
Send a message via AIM to jeffescortlx
Does the fuel pump run? Can you hear it humm?
I make slow Escorts less-slow.
My cardomain
jeffescortlx is offline   Reply With Quote
Old 07-28-2003, 05:26 AM   #5
ales
Forza Schumacher
ales's Avatar
ales Normal reputation
I'd do a little troubleshooting. First find out if the fuel is coming out of the fuel pump, then find out if it reaches the filter, then find out if it comes out of the filter. All by removing the respective hose from the fitting. And then replace the faulty part or fuel pipe/hose.
Old 07-28-2003, 06:24 AM   #6
t359
t359
stalled engine won't re-start
It's a mechanical fuel pump. Do I have to 'prime' this before it would draw from the tank(s)? Thought about injecting a bit of gas into the fuel inlet hose and trying it again. Thanks.
Old 07-28-2003, 11:28 AM   #7
ivymike1031
ivymike1031 Normal reputation
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Is your cam turning?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
ivymike1031 is offline   Reply With Quote
Old 07-28-2003, 11:33 AM   #8
t359
t359
stalled engine
As near as I can tell, the cam is turning. Strange, that the engine wold die when I turned the AC selector to the MAX, position. This has me stumped right now. Thanks.
Old 07-28-2003, 01:31 PM   #9
jeffescortlx
Check for spark. Than spray a little starter fuild down the carb to see if it fires. Than you can go from there.
My cardomain
Old 07-29-2003, 03:44 PM   #10
t359
t359
Engine stalled out---FIXED?
I have two tanks on this truck. I went uderneath to the switching valve and switched 2 fuels lines from left tank and put them where the right tank lines were, on the valve...and vice versa. It started! So I figured maybe a blockage in the line between the switching valve and one tank or in the tank itself. I blew compressed air through all four lines, into the tank. Replaced lines, started it and switched back and forth between tanks and it kept running. So perhaps there's something in there? Now, I just need to put new fuel line on and return the feeders to their original valve positions. Hope that's the end of this adventure! Thanks for all the help and suggetions! T359
Old 07-29-2003, 10:29 PM   #11
jeffescortlx
glad you got running.
My cardomain
Bookmarks
Google
Web AF
