Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Isuzu > Trooper/SLX
Old 07-24-2003, 09:39 PM   #1
budgirl
budgirl
'89 isuzu trooper ll won't start...:frown:
My 89 trooper ll has the 4ZE1 2.6 engine. It will not start but the symptoms started with the idle appearing low and it would stall when put in gear. It was sluggish in operation and occasionally would have no power at all with the pedal all the way to the floor and the vehicle on an incline. I changed the fuel pump, filter, hoses and wires and was able to get the vehicle to run for a short period of time, a bit sluggishly but once I shut it off, it would not start again. We double checked the fuel pump, hoses and wires twice with the same results (the vehicle runs, for a short time, low idle, but once stopped, it won't start again). I've been told it could be my I.A.C. valve and it has been suggested that I should unplug it to see if I can get it running without an idle and using the pedal to keep it running just to diagnose it. I've also been told it could be any number of other components such as the O2 sensor, fuel pressure guage and air flow sensor. I've blown out the feed line, the return line and the air line from the engine all the way to the tank and all is clear. I've checked for voltage and continuity in both ends of the harness for the fuel pump. I've hooked the fuel pump to the battery and suspended it in a bucket of fuel to confirm that it is working and it is but when I have it in the fuel tank and disconnect the feed line at the engine and turn the key, no fuel comes out. What is my next step? As you can see, I am at my wits end. I'm not sure if I'm supposed to be getting fuel out of the feed line at the engine or not. I would also like to rule out timing, valve clearance and compression. Those are way over my head and I would rather not waste time or money on those if they have nothing to do with my current problem. Please, help....Any worthy advice is much appreciated. I have to say that I've had this trooper for 4 years and this is the first problem I've had with it. I want my "picki" back up and runnin'. Thanks in advance.....
dawn....
budgirl is offline   Reply With Quote
Old 11-01-2003, 10:04 PM   #2
Andrews
Andrews Normal reputation
problem trooper
hi
I'm having a similar problem with an 89 trooper. To check the fuel pump, just get a fuel pressure guage and connect it before the pressure regulator(can be in a couple of different places, mines near the front end of the fuel rail). Then crank the engine and see if you have pressure. Incidently, If the fuel pump is running, you should be getting fuel out of the hose that enters the fuel rail.
I'm also having a real hard time figuring out what's wrong with mine. Its been to a dealer and garage with no success. I've narrowed my problem down to the ignition, the spark isn't strong enough or isn't timed right. Back to your problem, if you rule out fuel, then check the compression. Its not that hard but you do need a tool (guage). The manual says all cylinders are supposed to be around 170psi, with no big differences between cylinders. Then make sure your getting a spark at each plug.
Wish I could be more help.
Andy
Andrews is offline   Reply With Quote
Old 06-18-2007, 05:55 PM   #3
NVRDUNIZU
NVRDUNIZU Normal reputation
Re: '89 isuzu trooper ll won't start...:frown:
I Had The Same Problem With My 89 Trooper . It Turned Out To Be A Coolant Temp Sensor For The Computer On The Truck. There Are 2 Of The Sensor's One Is For Gauge In The Dash And The Other Is For The Trucks Computer. Basically If It Doesnt Read It Right It Thinks That The Engine Is Cold And Give It To Much Fuel On Start Up . Inturn Flooding Out The Engine Not Allowing It To Start. It Would Also Cause It To Run Really Rich Giving Me Bad Acceleration And Fuel Milage.
I Hope This Helps
NVRDUNIZU is offline   Reply With Quote
Old 06-27-2007, 10:01 AM   #4
soundrew
soundrew Normal reputation
Hi Dawn,
Have you pulled the spark plugs? If so, what did they look like? Black and sooty will likely mean you aren't having a fuel starvation problem. Have you checked the Mass Airflow Sensor (MAF)? Its just downstream from the air cleaner housing. When mine (88 trooper, 4ZE1) went bad- the fuel/air mixture was so screwed up that the truck ran like s#@t (like what you are describing) and it was so rich that when I popped the hood the exhaust was glowing red hot! Unplugging the electrical connector for the MAF should make it run better if the MAF is bad. The new part is.... brace yourself..... about $800 from a dealer. However, I was able to get one at a nearby junk yard for less than $50. In fact, I bought an extra one just in case this might happen again. Let me know if you need one and can't find it locally.
Andrew
soundrew is offline   Reply With Quote
Old 07-26-2007, 03:51 PM   #5
Tryumph
Tryumph Normal reputation
Same problem, easy cure (at least for me).
This also happened on my '89 Trooper. Although I have the 2.8 liter V6, not the four-banger, it has the same coolant sensors as described here ... and one of them going bad was, indeed, the cause of the problem. The part was less than $15 (might have been less than $10) at an auto parts store.
The Trooper usually wouldn't start, and when it did, it ran horribly. And if it died, it was almost impossible to restart.
The way I finally diagnosed the problem (after repeated attempts to start the Trooper) was to pull the relay for the fuel injection, crank the engine briefly to get all the excess gas out of the cylinders, then replace the relay. At that point, it would usually start again.
As always, whenever removing a sensor on an older vehicle, particularly one in contact with water, it's a good idea to apply PB Blaster or some other penetrating oil for several days before you try to remove it. In my case, the sensor came out (relatively) easily, but you never know ...
Tryumph is offline   Reply With Quote
Old 04-13-2009, 08:58 PM   #6
meanoman
meanoman Normal reputation
Thumbs down Re: '89 isuzu trooper ll won't start...:frown:
I have similar problems with 88 trooper w/2.6 I think may be coolant temp. sensor but can't find it. I find temp. sensor for gauge, but not for ecm computer
meanoman is offline   Reply With Quote
Old 05-10-2009, 03:33 AM   #7
gazzarama
gazzarama Normal reputation
HI, Ive got the same problem cant get 1st start up on Rodeo 95 4ze1 rebuilt engine. Had no fuel at the rail but got over that by finger over the end of the fuel pipe & bleeding the air out of the piping. With fuel to the rail it almost starts then later locks up almost with fuel. Irregular amounts of fuel, not much then heaps of fuel on the ends of the 4 plugs other times 2 plugs firing good, 2 wet with fuel. More headaches thanks garyb in Oz.
gazzarama is offline   Reply With Quote
Bookmarks
Google
Web AF
