need help with my 91gsx please
somedude
07-23-2003, 07:21 PM
My 91 gsx is a good car. I have one problem with it it smokes when I sit at an idle. When I go it has no problems but when i sit at an idle for a couple of minutes it wants to start smoking this gross blue smoke. I have had people tell me the turbo is going out but if you could please help me it would be great we did a comrpession test and it turned just fine so I have no idea what is wrong.
Spectrum
07-23-2003, 10:16 PM
sounds like dead turbo seals, Does it smoke hard on boost ?
FourG63 97GST
07-23-2003, 10:41 PM
Sounds like an excuse to get a turbo upgrade :bigthumb:
RockinWRX
07-24-2003, 12:06 AM
Sounds like it could only be valve stem seals. A leaking turbo seal would smoke ALL the time , and especially under boost. The older cars like that , the valves stem seals get old and dry out and crack , especially on the exhaust side , where the valve stem temps can top 500 degrees or more......:bloated: Its a major pain to change them , since you have to remove the cams , valve springs and retainers , everything . I removed my head completely and pulled everything off , its just easier to do that way.
Talon007
07-24-2003, 01:47 AM
Yeah it definetly sounds like stem seals. When you first start it up in the morning, run behind and check it, it should be really bad
somedude
07-24-2003, 01:09 PM
It is fine in the morning its just when I have been driving and stop at a light or if I warm it up and then get in and drive. It takes a couple of minuts for it to start smoking.
RockinWRX
07-24-2003, 04:42 PM
Might try routing your valve cover vent hose into a bottle. Its one of the first mods we do , and it could be the source of your problem. Oil can get into the intake from there , which would cause the smoking. Pull off the upper IC hose and see if theres a lot of oil in there. The PCV valve may be malfunctioning too. Theres a lot of reasons a car can smoke , including bad rings. Thats not typical on DSM's , so I would suggest doing the above to narrow it down. Turbo seals don't generally go bad unless the turbo was overboosted , or it was put away hot too many times. I'd also invest in a turbo timer....it would eliminate that particular problem on future turbo's that you install.
LandoAWD
07-24-2003, 04:57 PM
But then you have to explain to everyone and there grandma why your car is stil running and you are walking into the grocery store:disappoin
RockinWRX
07-24-2003, 05:13 PM
You are right . I got SO sick of that. :rolleyes:
"Hey , your car is still running..."
" YEAH , I KNOW , STFU , OK ? " :swear: :banghead: :chair:
Japmetal
07-24-2003, 05:46 PM
Just look at them, turn to look at your car, look back at the, with a "WTF" look and say "Does yours not do that ? Sh** !"
Or just ignore them completely - it's not like you wouldnt NOTICE your engine running as you got out the car !
