Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 07-22-2003, 04:50 PM   #1
Ariffel
Ariffel
02 Silverado Front suspension problems
I just bought a 02 Silverado and everything is great but I have noticed a slight vibration in the steering wheel when slightly turning. Like on a curvy street, you can feel something in the steering wheel almost like something is loose in the front end suspension. Would anyone have any ideas on what to check that could be causing the problem.. Thanks for any info..
Ariffel is offline   Reply With Quote
Old 07-22-2003, 07:48 PM   #2
aelwero
aelwero
could just be the type of tires you have on it, but check your tire pressure too, if it has even halfway offroad tires it's probably nothing.. my 4WD has all kinds of shimmies and vibrations that would be alarming if my firebird did it, but is usually nothing, especially if you play in the mud.. get the tires nice and muddy and then get on the freeway... it's quite a shock the first time you do it
aelwero is offline   Reply With Quote
Old 07-26-2004, 04:56 PM   #3
pall
pall Normal reputation
Re: 02 Silverado Front suspension problems
I know just what your problem Is . It is your innersteering shaft I had the same problem on my 2002 silverado it was covered under warranty
pall is offline   Reply With Quote
Old 07-28-2004, 09:58 PM   #4
02blackstallion
02blackstallion Normal reputation
Send a message via Yahoo to 02blackstallion
I also have that problem on my 2002 Z71
02blackstallion is offline   Reply With Quote
Old 07-28-2004, 11:37 PM   #5
Haw'n Hog
Haw'n Hog's Avatar
Haw'n Hog Normal reputation
My '99 Silverado (2WD) also shimmies, vibrates and bounces all over if the road is rough. If the road is smooth it rides and handles fine. I'm going to have the tires/rims balanced and aligned and the suspension checked out. I know, I know; it's a "truck", but I expect better! Will report back what we find.
Haw'n Hog is offline   Reply With Quote
Old 08-18-2004, 01:57 AM   #6
Bobbido
Bobbido Normal reputation
http://www.automotiveforums.com/vbul...d.php?t=265506
Hopefully this will help. I'm trying it soon. The vibration I'm getting going down the freeway is eating my tires up. I'm also getting that clunk sound every now and then when I turn the wheel. LOLuck to all of you, I know i'm gonna need it. I'll let you know if I get this Albatros off my back.
Bobbido is offline   Reply With Quote
Old 08-18-2004, 02:19 AM   #7
prtygood
prtygood Normal reputation
pall nailed it. your dealer will grease your middle section of the steering shaft. Takes about 45min.
prtygood is offline   Reply With Quote
Old 08-18-2004, 03:33 AM   #8
Bobbido
prtygood do you know if this innerstearing shaft and the intermediate shaft mentioned in the link on my last thread is the same thing. It looks like GM is stepping up and acknowledging one of several engineering design flaws. They suggest replacing the intermediate shaft rather than re-grease it.
Old 08-21-2004, 07:52 PM   #9
pickup02
pickup02 Normal reputation
I also have this problem on my 02 Silverado. Most noticeable when turning slowly. Thanks for the info that was posted here.
pickup02 is offline   Reply With Quote
Old 08-24-2004, 07:17 PM   #10
prtygood
You are correct. GM is now replacing the shaft insted of adding grease
Bookmarks
Google
Web AF
