Emissions Failed NOXL1_Guerito 07-20-2003, 01:25 PM Does anyone know a cheat to Pass NOX emissions testing, Failed with 3.05 max allowed is 2.5, When I got into to car to move after testing it was running hot. Any advice. Also AC compressor went out, uggggggh just my luck. Is it possible to replace compressor without having to take it to a shop and getting raped!!!!! Please help. My vehicle is 1993 Bonneville SSE has 156K miles on it, where is the EGR Valve anyways? Please help!!!!!! UGGGGGGGHHHHH:confused: :confused: Blue02R6 08-06-2003, 04:42 AM Originally posted by L1_Guerito Does anyone know a cheat to Pass NOX emissions testing, Failed with 3.05 max allowed is 2.5, When I got into to car to move after testing it was running hot. Well check with your DMV where I live if you fail, spend $200+ to get it to pass and it still fails they ignore it. Originally posted by L1_Guerito Is it possible to replace compressor without having to take it to a shop and getting raped!!!!! Yes, and no. Yes, you can replace the compressor yourself. No you can't do it with out the shop. They have to at least recharge the system to make it work. You should also have them recover the refrigerant before you work on it. 89 iroc-z 09-10-2003, 02:07 AM there is no egr on the 3.8 from 92 on up. but what you have is bad cat. the cat on that car is a 3 way cat and the nox part is bad. Automotive Network, Inc., Copyright ©2012
