Remote entry for Montero Sport??mb21532 07-20-2003, 08:56 AM Does anybody know if you can program more than two remotes for montero Sport 2002 entry system. When I try to program them when I get to the third one the two already programmed quit working. I have tried in the right sequence with same results. Is two the limit? Rockey 08-13-2003, 07:29 PM see the first post by Rockey and it explains how to do 2 remotes. mb21532 08-14-2003, 05:30 AM I already have programmed two remotes for it. My question is ....is two the limit that will work at a time? Rockey 08-14-2003, 11:24 AM I cant help you on that one. Thanks rsomers 12-18-2003, 01:14 AM I already have programmed two remotes for it. My question is ....is two the limit that will work at a time? My information says that 2 is the limit, from 2000-03. Hope this helps. bnloeb 04-21-2004, 10:19 PM can you help with programming instructions for a keyless fob for a 2001 Montero tj90 07-20-2004, 01:12 AM Check owners manual - I believe the limit is 4. dlkeener 10-30-2004, 06:00 PM how do you program keless entry for 2001 montero sport bukurz 07-13-2006, 04:22 PM How do you program keyless entry for a 1999 Montero Sport 4X4 . Automotive Network, Inc., Copyright ©2012
