Changing Oil Pumpkev309 07-17-2003, 12:11 PM I have a 2000 Cherokee Sport withe the 4L engine. I am changing to a high-flow oil pump, but I'm concerned about running into problems dropping the oil pan. For instance, is the exhaust system in the way? Do any parts need to be secured from movement during the work? Just not too sure of the internal layout of the pan and its surroundings. runuover 02-08-2005, 07:10 AM I have a 2000 Cherokee Sport withe the 4L engine. I am changing to a high-flow oil pump, but I'm concerned about running into problems dropping the oil pan. For instance, is the exhaust system in the way? Do any parts need to be secured from movement during the work? Just not too sure of the internal layout of the pan and its surroundings. it comes right out :smokin: scuba4321 02-08-2005, 02:51 PM I have a 2000 Cherokee Sport withe the 4L engine. I am changing to a high-flow oil pump, but I'm concerned about running into problems dropping the oil pan. For instance, is the exhaust system in the way? Do any parts need to be secured from movement during the work? Just not too sure of the internal layout of the pan and its surroundings. were are you getting your pump from? Automotive Network, Inc., Copyright ©2012
