I want to get wheels for my 2003 Alero. I thought 18 would be the biggest i could get, but then i saw a pic of someone with 19's. Does anyone know if 19's are possible without any tire well mods? Thanks.
__________________ "My keeper's eys are a shadow of brown that could never understand a blue-eyed type like me."
Yes, 19's will fit, but you will need to make sure the offset is correct. You will also need to run very small tires. I would advise against 19's, though. More strain on the engine, transmission, brakes, and suspension. 18's look plenty big.
I have a 2000 Alero GLS with a set of 215/35/19s. So, yes 19s will fit. I haven't had problems with acceleration or braking. If you purchase a rim that is within 10-15lbs of the factory rim weight, you should be okay (depending upon your driving conditions). My car stops on a dime: had to put it to the test involuntarily when a vehicle jumped in front of me when I was doing 86mph, and again (not the same day) when going home and a kid jetted out into the street.
The largest rim you can put on it is a 245/35/20. The only modification that you would have to do is to roll the rear fender well in with a bat (the wheel guys/gals should know how to do it). However, you'll only have to do it if you have excessive weight in the rear. Otherwise, a 20" rim with a 245/35 will fit just fine on the front and rear.
When mine arrive, send me your email address, and I'll send you a picture. I can send you one now of it with the 19s on it if you want. Just send me an email address.
