i screwed upDickButkus 07-13-2003, 03:10 PM I waS changing my transmission fluid and I stripped the inside of the drain, What should i buy and what is it called?? whtteg 07-13-2003, 11:42 PM Are you talking about the threads or the square hole you put the ratchet in? I fit is the thredas then you need a heli coil and a new plug, If it is the hole in the plug then you need a easy out set (bolt extractor) and a new plug.:bigthumb: Welcome to the boards:iceslolan Automotive Network, Inc., Copyright ©2012
