Cooling system problem??A_dangerlg 07-10-2003, 02:43 PM My car's been having some problems as of late. its a '98 sl2 w/ 99k mi. For some reason after driving for 1/2 or so my temp gauge starts jumping around causing my engine rev up and down. After doing that for a couple of minutes the gauge will jump way up and the Service Engine Soon light comes on and then the gauge goes back down to normal (at least for a few seconds, until it starts jumping around again). I have sufficient coolant in the car and i have no leaks, although, i don't seem to be getting enough pressure in my cooling system since i can pretty easily squeeze the hose that connects the engine to the radiator. I think that indicates a pressure problem. I've checked around and it sounds like it could be one of about a thousand different problems. I'm just trying to get it narrowed down a bit before I start spending money to fix it. Some of the problems I've heard of might be: 1. bad radiator cap 2. bad thermostat 3. bad temp sensor 4. clogged hose 5. broken fan or a combination of any of the aforementioned. Has anyone had the same problems? I dont want to go out and start spending $$ on something that may or may not fix the problem. Turbopowersaturn 07-22-2003, 06:09 PM You have a bad coolant sensor more than likely. Derek PA Automotive Network, Inc., Copyright ©2012
