96 leaksNightride69 07-10-2003, 04:15 AM I have a 96 corsica and the front floor and back floor are soaked. Any idea why and where it could be leaking from?? Thanks Nightride69 icon 11-01-2003, 03:43 PM Could be the weather stripping/molding that wraps around the door frames. Do the doors seem lined up and do they close ok? Sometimes the stripping becomes shifted, and even though it looks ok, it may need to be adjusted. If they are still in decent shape, take them off and stick a little strip caulk on the frame, then put the weather stripping back on. This may help. (*caution* the caulk can get messy.) I had that problem w/ a beretta and it sucks! Car was flooded. kharris 12-17-2003, 08:44 AM the seam under the rack and pinion steering on the firewall tends to rust or leak water on corsicas and berettas. You must reseal the seam or patch if it is rusted out. You may pull up the carpet on the driver's side front and look at firewall. Mine is patched with sheet metal and silicone. This stopped the leak as water was on the entire floor in front and back. hope this info helps you. thetoy04 12-30-2003, 05:32 PM does it only leak when it rains or not it could also be your heater core has busted that does hold alot of water in that system. Sad_Sole 08-03-2004, 09:45 PM I am haveing a very bad prob with water in drive side back floor board and in trunk. i have replaced all the striping and resealed the underbody. I am all out of ideas. corsifreek 08-04-2004, 03:05 PM corsicas had a recall notice for havin leaks in the firewalls. i have the same problem. it only does it when it rains real hard. i recomend findin the spot and sealin it with caulk or do what i did i just park it in the gagrage now:) Automotive Network, Inc., Copyright ©2012
