Transmission Swapzero G 07-09-2003, 01:18 PM I have a 93 Saturn SC2 automatic. I have done a good bit of work under the hood and would like to put in a manual transmission. I would like to know if this is possible and if so what is required to do the swat and what problems may I encounter along the way. AkinaSpeedStar 07-12-2003, 01:33 AM its possable i have seen it done, the junkyard is your best bet for the parts you will need, grap the whole trans and mounts and shift linkage, clutch cylender, all the lines and the inside middle councel, the pedal and that whole asemably, and anything else that looks like it needs to go, go over your car first and see what is all there, than go look at the 5 speed and see what is all there and take what you need, i think you might have to drill through the fire wall, but im not to sure, i have a friend who has done it before i wil try to get a hold of him and give you more info, i have only helped him get the parts. Automotive Network, Inc., Copyright ©2012
