Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 07-09-2003, 10:13 AM   #1
AnthonyJohn
AnthonyJohn
Angry 2000 Malibu
Re: 2000 Malibu, standard V-6
My dealer says that the LOUD ticking that I hear at start-up (and EXTREMELY LOUD in winter), and last for 3-4 minutes is "normal noise" and that GM has issued a bulletin saying so. My mechanic feels that it is a sign of a bigger problem that may affect the engine in the future. Can any answer this question? Thanks, AnthonyJohn
AnthonyJohn is offline   Reply With Quote
Old 10-25-2003, 09:46 PM   #2
pgmalibu01
pgmalibu01 Normal reputation
The early N-body vehicles had a TSB issued for engine noise. There were excessive clearances between the pistons and cylinders. Check with GM and the NHTSB web site and do a TSB search for this car. Good luck
pgmalibu01 is offline   Reply With Quote
Old 06-26-2008, 11:23 PM   #3
dewangxp
dewangxp Normal reputation
Re: 2000 Malibu
Engine - Ticking Noise on Cold Start Up
File In Section: 06 - Engine/Propulsion System
Bulletin No.: 01-06-01-005
Date: January, 2001
TECHNICAL
Subject:
Cold Engine Tick Noise
(Replace Pistons)
Models:
2000-01 Buick Century
2000-01 Chevrolet Lumina, Malibu
2000-01 Pontiac Grand Prix
with 3.1L Engine (VIN J - RPO LG8)
Condition
Some customers may comment on a ticking noise (similar, but not related to valve or lifter noise) that occurs 10-15 seconds after a cold engine start. The noise will last for 1 to 2 minutes, and will fade as the engine reaches operating temperature.
Cause
The noise may be caused by excessive piston to bore clearance during cold engine operation resulting from the specific piston design used in cylinders 1 through 4.
Correction
Service pistons for cylinders 1 through 4 will now be of the same design of those used for all production 2000 and 2001 for cylinders 5 and 6, and will have polymer coated piston skirts. Pistons in cylinders 5 and 6 are not exhibiting the described noise condition.
Important : ^Note that this is a customer annoyance issue, and does not affect the durability or life of the engine.^Removal of pistons from engine cylinders 5 and 6 is NOT necessary if equipped with polymer coated pistons. It is recommended to rotate the crankshaft until the piston skirt is exposed in the lower crankcase area for inspection. Replace pistons in engine cylinder positions 5 and 6 ONLY if there is evidence of damage to the polymer coating on the piston skirt, or scoring on the cylinder wall (heavy scratches) is evident. Detailed diagnosis of cylinder wall/piston skirt wear is discussed in step 4.
dewangxp is offline   Reply With Quote
Old 06-29-2008, 08:55 AM   #4
AD2BU
AD2BU Normal reputation
Re: 2000 Malibu
I have a 98 Malibu LS (3.1L V6) and I recently added Lucas Oil symthetic additive to the crankcase. That quieted down the noise considerably and I think it even idles quieter. Note that Lucas Oil recommends their synthetic additive for vehicles using regular (non-synthetic) oil. Good luck.
AD2BU is offline   Reply With Quote
Old 10-06-2008, 11:37 PM   #5
Will Help
Will Help Normal reputation
Re: 2000 Malibu
Also, useing a good oil filter with an anti-drainback valve helps keep dry starts to a minimum. I could tell the differance when the garage put the wrong filter on my 2002, 3.4. It rattled alot on start-up. I made them correct the problem right away. It doesn't rattle 10 seconds with the anti-drainback valve. I also use full synthetic oil ( 5W50 ) and at 197,000 miles I use less than 1/4 quart of oil between changes.
Will Help is offline   Reply With Quote
Old 10-24-2008, 03:19 PM   #6
4x12
4x12 Normal reputation
Re: 2000 Malibu
Hi Guys,
1st post here...
I also own a 2000 LS and those ticking/rattling problems ae normal on the 3.1 Malibus. Mine got so bad that the changed the engine... when they opened it up they said it was shot! I was lucky enough to have some warranty left on it so I saved about $2400.
But this car as been a non-stop issue 2 years into the purchase.
Best of luck to ya...
P.S.
The new engine is starting to act up
4x12 is offline   Reply With Quote
Old 10-24-2008, 05:29 PM   #7
cbec1999
cbec1999 0
Re: 2000 Malibu
Don't say stuff to me. Show me.
cbec1999 is offline   Reply With Quote
Old 10-24-2008, 05:33 PM   #8
cbec1999
cbec1999 0
Re: 2000 Malibu
That's probably because the engine is just like the old one. Put it IN WRITING, and send it CERTIFIED MAIL to the dealer.
When is does a meltdown, you save $2400 again, on motor #3.
Bookmarks
Google
Web AF
