CHEAP boost control for R33
turbomad
11-16-2001, 11:50 PM
For all you guys sick of 2 stage boost on your 33's try this....
go to a hardware store and get a brass gas needle valve tap ($25), go to ENZED or a similar hydraulic shop and get two barbed hose fittings that will screw onto the brass tap ($4).
Pull the two hoses off the boost solenoid and connect them to the brass tap, by opening the tap you get more boost, close it for less.
I've set mine on 9psi and it only spikes to 10psi on quick gear changes which is less spiking than my Turbosmart controller used to give.
