In the boot, there is a metal cover on the right hand side, underneath it is another plate and underneath that is the fuel pump There is probably a leak in the lower plate. Thats where mine came from.
ER.. u sure that its petrol and not exhaust fumes? (just checking)
the one I had was the breather from the fuel filler was cracked in mine you will need to remove the shrould in the wheel arch to see that.
meggala
check out my site
http://www.meggala.com
jdm info and drifting stuff
nissan cefiro a31 fitted with
sr20 and trust t518z turbo.
13.3 @ 105.69 mph 2.069 60'
full street trim
Pressure test? . no no. Its just a metal cover on top of the fuel tank.Fuel leaks out when its sloshing around in the tank. Just needs some sealant to seal it
tell me, does anyone know if it actually matters if it leaks around the fuel pump seal? I replaced my fuel pump and the seal streached so In cut it and put it back in. When I remove my fuel cap it dosn't make the "hiss" noise... but the car runs sweet and gas is normal for the car..
