De-Limiterpalmer_paul 11-16-2001, 05:46 PM I know that you must think not again, but which wire is it that you cut for the Limiter on the R32?, 55 or 53?. If the speedo reads 180kph do all skylines have limiters on them?. Pablo. denjam69 11-16-2001, 08:30 PM only 1 way to test the limited out!! hit the limiter down a 50km/h zone :D palmer_paul 11-16-2001, 09:28 PM Could you enlighten me as to what you mean hit the limiter in a 50 zone?. :rolleyes: denjam69 11-16-2001, 09:32 PM wind it out in 5th!!! in a 50km/h zone palmer_paul 11-16-2001, 09:41 PM I have an Auto box, Does this make a difference?. By flooring it what would be the signal that the car has a limiter. Sorry but i am new to this game. :cool: denjam69 11-16-2001, 09:47 PM when u hit the limiter the comp shuts the fuel pump down for a few seconds and u will feel the car surge and the engine cut off for a few seconds each time u hit the limiter! palmer_paul 11-16-2001, 09:51 PM If it has the limiter is it the wire 55 or 53 that needs to be cut? any idea?. Thanks for the advice. :p denjam69 11-16-2001, 10:04 PM cant rememebr, read the other threads its in there palmer_paul 11-16-2001, 10:11 PM thanks for your help. :) Dak 11-17-2001, 02:33 AM Wire 53 Darren 11-17-2001, 02:52 AM If you have never hit the speed limiter you don't need to cut it! I think the limiter pumps extra fuel in so it runs too rich, it coughs splutters and if you keep you foot in it it backfires with a huge cloud of black smoke. The GTR use to hit the speed limiter in 3rd before it hit the rev limiter -Joel- 11-17-2001, 05:08 AM i was going to say cutting the fuel pump under full load definately in my book would = lower fuel pressure = detonation... OUCH... :bloated: SlowGts-t 11-17-2001, 06:22 AM its probably an ignition cut then. GTS-4 Ben 11-17-2001, 06:47 AM Ignition cut... Wire 53 is the one.. but don't tell everyone... we want to have some we can pass at over 180kph :D You may still get a cut in 4th gear at over 200kph, I think changing to 5th will fix it. Ben denjam69 11-17-2001, 08:59 PM changing to 5th aint gonna make no difference to the speed cut limiter! palmer_paul 11-17-2001, 09:48 PM If it's an auto what is the max speed with the limiter off? :eek: GTS-4 Ben 11-17-2001, 10:58 PM Originally posted by denjam69 changing to 5th aint gonna make no difference to the speed cut limiter! I am not talking about the Speed Cut... they come in a 180. I am talking about the AFM Ignition cut that you may get at over 7000RPM in 4th. In 5th it should be fine... Ben palmer_paul 11-17-2001, 11:13 PM Ben, Excuse my ignorance, but does the speed limiter cut in at 180km/h?. If so is there a way of doing away with this...I am trying to get my head around all these limiters!!!!!!!!!!!!!. Paul. palmer_paul 11-17-2001, 11:14 PM Ben, Like the cars by the way, are they all yours?. paul. GTS-4 Ben 11-17-2001, 11:43 PM Yes the "speed" limiter is at 180kph. The other one happens for me at over 200kph, but it is different and to do with the AFM, I don't know how to fix that.? On the R32 Skyline, wire #53 on the ECU is for vehile speed sensor, cutting that will get rid of the 180kph limit. The grey GTS-4 is mine, I have sold the White GTS-T (that pic it has 18" AVS's on it.. off a GTR, WAY TOO BIG) Ben palmer_paul 11-17-2001, 11:53 PM Ben, Really appreciate the advice, like the grey one, has yours the RB25DET engine, What speed have you had out of yours with the LIMITER off. Paul. P.S After around 120kl/h i am sure I acn hear a chime sound somewhere for a second,,do you know what it is? paul. GTS-4 Ben 11-17-2001, 11:56 PM RB20DET. I hit the AFM cut at around 215kph, had alot! to go. The chime is behind your speedo, a little box. But if you remove it you wont get a warning when you open you door and have the lights on. Ben palmer_paul 11-18-2001, 12:07 AM ben, what mods have you done to get that sort of performance?, Any mods you recommend, I only have a air induction kit, the rest is standard, What after market exhaust would you recommend, as theres so many. Blitz/ Kakimoto/HKS!!!!!!!!!. paul. GTS-4 Ben 11-18-2001, 12:53 AM Well 4WD helps, but I learnt to drive, that my best mod ;) I have 3" from turbo, Pod filter and a brass button clutch. 14 psi. Good for a 14.0 1/4. My exaust is just a custom made one, seems to do the trick for $400, there is no way I am going to pay $2000 for an exaust... -Joel- 11-18-2001, 01:01 AM U'r Still running the stock Terbs then... What Rwkw u get? Dak 11-18-2001, 01:47 AM I think he means by the time you hit over 200 in 4th you'll be hitting the rev limiter :) Sub Boy 11-18-2001, 02:27 AM I heard that cutting the 53 wire stuffs up the Hicas.....True or a Harry Potter?:confused: GTS-4 Ben 11-18-2001, 04:05 AM Nope, HICAS is fine with it cut. I think you get just over 200k in 4th at limiter... what I am saying is that because the engine is strained.. it gets another cut.. so put it in 5th to go over 200kph. I am still running stock turbo, no sure on my HP. I am putting a larger turbo on next week though. Ben primo 11-19-2001, 11:43 PM how bout gettin a remaped chip for you puter i can get them exchange for $200 greatly improves off boost response for autos runs australian fuel without pinging 180 klm limit is removed and boost cut removed maped for standard car with 3"exhaust bost is adjustable to 14psi GTS-4 Ben 11-20-2001, 08:54 AM don't rate chips. Limiter is removed for free. Boost cut.. well dosn't exist. I have a 3" exaust and 14psi.. and it runs magic! Ben [TWUBLE] 11-20-2001, 05:47 PM Originally posted by denjam69 changing to 5th aint gonna make no difference to the speed cut limiter! mmmmm life begins at 180!!! :) (well not for those who havnt taken the snips to wire 53!!! :P ) mind you with my top end haha well i wont go there... i have top end? hrmmm :bandit: :bandit: Chopper 11-22-2001, 09:51 PM Where is wire 53? Had my computer out today and can't find any markings as to what wire is what number. :confused: [TWUBLE] 11-22-2001, 10:09 PM Chopper click the link below... its a diagram of the computer wiring loom and shows you which wir #53 is :smoka: Chopper 11-22-2001, 11:05 PM Cheers TWUBLE. Done it. Couldn't test it properly though. Got 180 easy, but there was too much traffic. Try tomorrow when I go to work. BTW, is that screw on the ECU the idle adjustment. Think I knocked it and it's idling sloooowww. 'Bout 400rpm. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
