Difference between 175 hp on I4 and 175 hp on V6/I6?
DriverEnthusiast
07-03-2003, 09:22 PM
Basically, is there any performance difference? Will one type of engine invariable have higher torque, or perhaps greatest HP at lower RPM? If you had to choose between the two engines, which one would you take?
BeEfCaKe
07-04-2003, 06:47 PM
I4 is probably going to be more fuel-efficient... and I would think it would be on a lighter chassis also compared to the V6/I6 car.. Torque-wise.. I would think V6/I6 would have advantage? Maybe someone could explain... I don't feel like typing =\
PWMAN
07-04-2003, 08:47 PM
It depends on what size the engine is, and who makes it.
SaabJohan
07-05-2003, 12:46 PM
Torque-wise there are no difference between the two types of engines. The V6 are however, in general, smoother but the I4 are probably lighter and consumes less fuel.
PWMAN
07-05-2003, 01:14 PM
How can you make that statement? If you had a 1.6L I4, and a 4.9L I6, which do you think is going to make more torque? Even if they made the same HP the I6 is going to make loads more torque. The larger the displacement the more torque and engine makes, but there are some variables that can differ that like cam selection.
Your whole post is way off base, V6 is smoother? How can you say that too? I guarentee that I4 in my mom's integra is WAY smoother than the V6 is my Grandma's Chrysler Sebring. They both smooth to my standards, but I'm use to the rumble of a V6. My mom's integra you can't even feel or hear it running at an idle.
The question is what size are the engines? Are they both the same displacement? How heavy of a car is it in? There are too many variables to answer this question properly.
DriverEnthusiast
07-07-2003, 10:09 PM
No particular engines I want to compare, just wanted to know what advantages a V6 has over an I4 if the HP numbers are identical.
PWMAN
07-07-2003, 10:20 PM
There's no way of answering that accurately without more facts. Like what size are the engines? Obviously if you are comparing a 1.6L I4 to a 3.2L V6 the 6 is going to have way more torque. Generally speaking, the more displacement the more torque an engine will make.
darkaccord
07-07-2003, 10:50 PM
A "V" can generally rev a bit higher than an inline.
PWMAN
07-07-2003, 10:55 PM
Tell that to a person that owns a GSR integra...
8200 RPM, stock. Most get aftermarket ECU's that let you rev to 9K. Insane huh?
SaabJohan
07-14-2003, 08:33 AM
Yes there is, I just did it above. When comparing two engine types you suppose that everthing else is equal.
A 6 cylinder engine (4 stroke) will give 6 power strokes per 2 revs, while a 4 cylinder will make only 4 per 2 revs.
In a four cylinder engine the secondary reciprocating inertia force isn't balanced, while on a 60 degree V6 it is.
darkaccord: A V engine cannot rev higher because it's of V-type.
darkaccord
07-14-2003, 10:16 AM
A "V" engine can rev higher because the movement of the pistons counteract each others inerta better than an inline.
ivymike1031
07-14-2003, 10:59 AM
*cough* bullshit *cough*
jhillyer
03-21-2004, 02:19 PM
The peak horsepower figures have been given: 175hp, so matters not if a v6 could spin at a higher speed than a i6.
I'll consider the i4 is not the same displacement as the v6, perhaps i4 at 2.0l and v6 at 2.5l and the i4 has reached some 8000 rpm to deliver what the v6 does at 6000rpm
I would choose the v6 over the i6 if I noticed the v6 were designed allowing the cylinders to be mounted closer with a shorter crank than that of the i6, creating a shorter block much like the VR6, ignoring other traits.
Normally breathing, for the same displacement between 4 and 6, I would choose either of the 6 over the 4, if the materials and stroke geometry were similar, for smaller but more frequent piston pushes per crank rotation and less effective loading per stroke. If I wanted simpler intake and exhaust plumbing, I'd choose the inline over the vee.
(to be continued)
burly
03-24-2004, 04:51 AM
Something else to take into account are the power and torque curves. Even if the V-6 has similiar torque peaks, the torque curve is probably fatter than that of the I-4. It also probably comes on at a lower RPM. Usually the low RPM torque on V-6s (partially due to the increased displacement) is higher than a I-4 at the same RPM. Same goes for HP since torque is a factor in the HP equation.
A good real life comparision is the 350Z's 3.5L V6 and the S2000's
The 350 Z's engine specs:
3.5-liter DOHC 24-valve V6 engine
287 hp @ 6,200 rpm
274 lb-ft @ 4,800 rpm
The S2000's engine specs:
2.2L In-Line 4-Cylinder
240 HP @ 7800 rpm
162 lb.-ft. @ 6500 rpm
Performance wise on the track, the 2 cars put out very similiar numbers. HP wise, the engines are similiar. However, the I-4 must be kept running at a much higher RPM to produce similar HP numbers as the V6. What this translates into, is drivability. Around town the V6 powered car will accelerate with much less pedal effort and probably a lot smoother than the I-4. On the highway, the V-6 may not have more passing power, but it can do it with either no downshift or just single gear where the I-4 would have to drop one or more gears and rev much higher to deliver similar passing power. This is why expensive luxury sedans often use smooth V-8 engines that deliver good torque and a smooth powerband - power for 3/10ths - 7/10ths driving with minimal drama.
SaabJohan
03-24-2004, 04:26 PM
burly, jhillyer
You're making many assumptions, for all we know the I4 could be the one with the higher displacement. Or perhaps it's the one that is turbocharged.
Maximum power output at high rpm isn't equal to poor driveability. Driveability has more to do with the power/torque curve, and notice that I wrote curve, the values themself are not that important. Then driveability for racing and daily driving differs, most manufacturers of F1 engines will probably say that their engines has good driveability, putting one of those engines in a normal car and give it to a daily driver and he will most likely not agree. A racing engine usually delivers a smooth curve in the upper part of the rpm range and the engine for the daily driver delivers a smooth curve in the lower part of the rpm range.
Most car manufacturers are trying to make cars that during daily driving can be driven with more "pedal effort" as this will reduce fuel consumption.
buymeabmwm3
03-24-2004, 04:51 PM
Its all about personal preferences anyways. There are so many factors to weigh on engine characters, torque, hp, configuration, displacement, manufacturer. Best way is to go out and sample engines to see what things you like. I wwould never buy anything other than a german I6, some poeple swear by turbo 4s and others would only take a big american V8.
burly
03-24-2004, 06:20 PM
Well, I stated that I was making many assumptions. Given only that the originial question asks the difference between an I-4 and a V-6 of equal peak HP, many assumptions have to be made to even carry a discussion. However, in general, it is safe to assume that the V6 is of greater displacement than the I4 and that the I4 is not turbocharged. If these don't hold true, then the conversation is even more complex and a direct engine to engine comparision would have to be made.
As far as driveability and curves go, thats what I was getting at, that the power/torque curve has more effect on the driveability than the peak power. That is the reason I compared the two engines that I did. The power curve on the I4, while peaking at a similar number as the V6, has a much steeper power curve that is high RPM biased. The V6 has a flat curve that is more center biased. If I had the graph, it would be a much easier explanation.
In other words, if you really want to compare the two, we need the specific two engines in the comparision, and the cars they are in.
Steel
03-24-2004, 08:38 PM
By the by, the only V engine that is naturally balanced is a V12, because it is basically comprised of 2 I6's next to each other, since I6's are naturally balanced. Boxer engines balance naturally too, buuut that's about it.
Some1else
03-24-2004, 09:11 PM
Yup,
I would agree. You can argue all kinds of engine design, and manufactures all day. The fact remains the I6 is the most balanced engine made. Also, because of this, they tend to have the best low-end torque. Just look at F-150’s. The I6 motor has more low-end torque then the V8 (that would be the 5.0 ltr.), same manufacturer, and bigger V8 as compaired to smaller strait 6.
On a side note, I have an 944 2.5 liter I4, and a V6 3.0 liter, SOHC Stealth. Both rated around 160-170 HP. Granted my 944 has balance shafts to counter act the “large” I4 vibration problem, but personally I enjoy the 944 more because it seems to get to the power band faster, and have better acceleration at freeway speeds. But that is my opinion. I have no real numbers on it.
jhillyer
03-24-2004, 10:08 PM
burly, jhillyer
Nooo, the i4 is supercharged with nitrous, and the i6 in question is really two halves of a flat-6 with water injection.
The potential of turbo is not so relevant when it was not mentioned in the initial posting, and the peak power has already been given. We're not allowed to add a turbo and make 240 (b)hp out of a 175 i4, so set a mental firewall at 175. I'm hoping we can center our comments about the "difference between 175 hp I4 and 175 hp V/I6", and not so much on upgrade equipment.
I agree about your mention of rpm and drivability. Because except for solid-solid clutch engagement, higher RPM (or more working cylinders per crank moment) results in smoother power output. Lower the RPM or reduce the cylinders pumping, and we get more warble in the loaded output.
Besides, we just learned the i6 is really a diesel 13BT peripheral intake rotary with variable compression between 16:1 and 22:1, or maybe not.
beef_bourito
03-28-2004, 07:03 PM
i would thikn that the I6/4 would rev higher than the v6 because the V needs to turn 2 camshafts rather than one so less loss to that.
just my sort of informed theory.
PWMAN
03-28-2004, 07:13 PM
how are you informed??? and by who?
Most V6's are OHV, meaning 1 cam. Only if it's OHC does it have 2 cams. Besides, 90% of 4 cylinders now are DOHC, so they have 2 cams to turn also.
4 cylinders rev higher due to less recipricating mass, otherwise a V engine configuration can rev higher. Example, a 300 straight 6 ford, and a 4.3L chevy V6, the ford can rev to like 4000 RPM and the chevy V6 can rev easily to 6K.
Another example, a V4 motorcyle engine and an I4 honda. Motorcycle-9-10K easy if not more, honda-most only to 7500 but the S2000 engine to 9K(rare exception).
Once again it's only because of recipricating mass that an I4 can rev higher that a V6. Also a larger cubic in engine will generally rev higher anyway, so a V6 will more than likely be more CID.
beef_bourito
03-28-2004, 07:21 PM
by sort of informed i meant from what i've heard on this forum. if you have a v engine with SOHC dont you have one cam on either side. also i thought more moving parts=more power loss. i'm not an expert, as it's probably obvious from my previous posts besides i'm only 15 so i dont have much car experience, but from what i've heard from this forum i thought an I4/6 would rev higher than a V6 because of less moving parts.
Some1else
03-28-2004, 08:11 PM
Err? You're going to have to pick one. Either the "less recipricating mass", or "larger cubic in engine will generally rev higher anyway"
Sorry, not a flame! :smile:
On a side note, most street bikes red line at or above 11,000 RPM, and thus agreeing with your point, "less recipricating mass". This is one case where smaller is better! :eek7:
spooleffect
03-28-2004, 08:18 PM
This is the most over simplified question with the most complicated answer Ive every seen. There are WAY to many factors in determining the answer. Bore, Stroke, Rod Length, Cylinder Arrangment(ie stroke angle), Induction Type, Head Design, Cam Profile, Compression Ration, etc, etc , and etc. There are WAY to many engineering factors to take into account.
This is a horrible question.
I can't even try to answer this question with a really simple answer either. But I will try.
I-6= Will peak 175hp at a lower rpm and have a broader flatter power curve.
V-6= Will need a bit more rpm to mak the 175hp peak and will make good mid range power on the way to that number but it will not produce as much torque as the I-6.
I-4= Will need more rpm than the 6's to make the 175hp number, it will not produce lower power numbers like the 6's but the engine will do better as the rpms climb. It will have a steeper power curve than the v-6 and will not have flat curve of the I-6.
This is assuming all have equally displacment~2.5L, head design, induction, fuel characteristics, etc, and will make 175 peak horsepower. To put it simple each engine is as identicle to the others as it can be. Don't add in yeah but what if remarks. This is just a simple answer to the question
PWMAN
03-28-2004, 08:23 PM
Thats not a contradiction. A larger CID engine will have more recipricating mass I.E. larger pistons and crank stroke.
Oh sorry I meant to say larger CID engine will NOT rev as high.
PWMAN
03-28-2004, 08:25 PM
Most street bikes aren't V4's :)
PWMAN
03-28-2004, 08:29 PM
Yes, thats why I specified between OHV and OHC. Most V6's are OHV, and only have 1 camshaft. yes some V6's are SOHC BUT most 4 cylinders are DOHC meaning they have 2 cams to turn also. PLUS a V6 cams are shorter and don't weigh as much(less recipricating mass) as a 4 cylinders cams.
''recipricating mass'' is the word of the day :icon16:
:iceslolan
VQuick
03-28-2004, 09:12 PM
I've seen the comparisons here, and it looks like no one is really using motors of the same displacement. That's a big factor in how a motor will behave vs. another.
Since I know more about Nissans than other manufacturers, I'll use their engines as an example. All motors here are 2L.
FJ20DE(DOHC I4):147hp
SR20DE(DOHC I4):140hp-165hp
RB20DE(DOHC I6):152hp
VG20E(SOHC V6):113hp
VQ20DE(DOHC V6):168hp
Now the turbo 2L versions. There is no 2L VQ turbo.
FJ20DET(DOHC I4):187hp
SR20DET(DOHC I4):205-247hp
RB20ET(DOHC I6):144hp
RB20DET(DOHC I6):211hp
VG20ET(SOHC V6):147hp
Here's the 2.5L engines. Same order.
QR25DE(DOHC I4):175hp
RB25DE(DOHC I6):187hp
VQ25DE(DOHC V6):187hp
Now on to the 2.5L turbos. There is no QR turbo.
RB25DET(DOHC I6):276hp
VQ25DET(DOHC V6):276hp
Here's two 3Ls, both V6.
VG30DE(DOHC V6):226hp
VQ30DE(DOHC V6):190-222hp
Just for the heck of it, here's the turbo versions.
VG30DET(DOHC V6):250hp
VQ30DET(DOHC V6):276hp, but probably more, since the 2.5L turbo already produces that much. You know, because of the whole Japanese 'Gentleman's Agreement' and all.
Hope this all helps. :)
PWMAN
03-28-2004, 09:20 PM
Could you give the RPM's those HP ratings are at? How about the torque specs?
Some1else
03-29-2004, 05:30 PM
Roger! :biggrin:
Could very well be, but the idea still stands! :)
OT. I had a friend with an RZ 350. Last of the street legal two strokes, and that thing had a red line of 13,500 rpms. Wouldn’t go over about 90 mph, but it would get there yesterday, and you could pick it up with little effort!! :smokin:
PWMAN
03-29-2004, 05:49 PM
2 strokes are a little different my friend :iceslolan
dampachi
03-29-2004, 10:14 PM
I don't know if anyone said this yet because I didn't feel like reading the whole damn discussion....but 175hp is 175hp. I4, V6, VR6, I6, you name it. but now when you bring in other factors such as torque which of course a higher cube engine is going to produce more of..shit changes. but first of all...why? what's the point of the thread? are you trying to figure out what would win in a race? or just want to know differences other than the obvious?
VQuick
03-30-2004, 09:47 AM
I'll try later on today. Look for an edit in my original post. I might not be able to find 'em all, though. Believe it or not, it was pretty hard just to find the power ratings.
The page where I found most of those engines was from Australia, so I had to convert the kw ratings to ps(international hp), then to standard US hp. :icon16:
