help only first gearHornnumb2 07-02-2003, 07:58 PM I have a 94 seville sts and it will not change out of first, it has some surging when idleing in park. I tried to get the trouble codes and I get about 10 history codes but the start with PO34. I cant find any codes that start with a P anywhere. Thanks Michael tdnyc 07-02-2003, 11:35 PM My first guess would be that your tranny siezed.:smile: jim j 10-27-2003, 09:02 AM :screwy: I have a 95 SLS that is doing the same thing, will not upshift from 1st. I have heard it could be related to a possible ingnition switch problem (worn out). Anyone else experience the same thing??? luv2bowl 03-29-2004, 03:15 PM I think I had the same problem, 95 SLS, I had the trans rebuilt, and continued to have various problems. Turns out there was a wire that shorted out in the trans. Didn't find out if this was the problem all long, or just an additional problem. In any event, stay away from Cottman. jim j 03-30-2004, 08:56 AM My problem ended up being the shift solenoids inside the tranny. $100 in parts and a couple hundred for labor and I was back on the road. The onboard message center nailed the error codes down to the solenoids. When the shop dropped the pan that was the only problem. CADIBROUGHAM 06-28-2004, 01:30 PM Is Your Battery Good Remeber That Those Tranny Are Electric And If They Do Not Have Enough Power They Wont Shift. I Was At The Store When I Started By 91 Seville Just Fine And Drove Down The Street It Would Not Shift Out Of 1st. I Had It Towed Home I Decided To Put In A New Battery Because I Had No Tranny Problems Before.that Fixed It. sparkling3usus 08-31-2004, 04:50 PM I just had the same problem with my car. I drove around in 1st gear for 3 months. Nobody would touch it. So I got onto a forum and started researching. I checked my codes and it was po29, the solenoid a and b. I did the job myself. It took me 3 and a half hours and mind you. I'm a women and have never worked on cars. I got some good directions. Automotive Network, Inc., Copyright ©2012
